Glitter Candle Jar DIY
4,998
124
5
Published
Introduction: Glitter Candle Jar DIY
This is a pretty easy DIY candle holder. The glitter on the jar has a lovely way of catching the light from the candle inside, which I love. Let's get started!
Step 1: What You Need.
  • Candle
  • Empty jar
  • Glue
  • Glitter
  • Newspaper (to protect workspace)
Step 2: Coat the Inside of Your Jar With Glue, Only As High Up As You Want the Glitter to Go.
I did this with bare hands, but an alternative would be to put a napkin on your hand like a glove and smear it around like that. Use enough glue that it fully coats the inside of the jar that you want glittered, but not so much that it drips.
I avoided getting glue and glitter on the bottom of the jar because I wanted a smooth surface to let the candle rest on.
Step 3: Dump the Glitter Into the Jar.
Roll the jar around in circles until all of the glued parts are coated with glitter, and then knock the jar into a bowl to get rid of excess glitter. You can dump the bowl back into your glitter container for later use.
Step 4: Let Your Jar Dry Completely Before Putting a Candle in It.
Be sure that your jar is big enough that the candle doesn't touch the edges; I'm not sure what heat does to regular Elmer's glue, so in case it can liquefy it and make the glue run, I'm sticking with a tea light despite the size of my jar. And then, ta-da, you have a glittery, pretty candle holder!
  • Stick It! Contest
    Stick It! Contest
  • Oil Contest
    Oil Contest
  • Woodworking Contest
    Woodworking Contest
5 Comments
