Glitter Slime
Introduction: Glitter Slime
I've been trying to track down a large amount of clear glue for a while, the craft stores I usually frequent can't seem to keep the 1 gallon jugs in stock so I had to make due with the smaller bottles. Clear glue is a bit different from the white glue so more experimenting was needed.
Step 1: BoM
Clear glue
Warm water
Craft sticks
Step 2: Glue
Mix 4oz of clear glue with 1/4 cup of warm water. Stir well.
Some slime recipes call for using pre-made clear glitter glue, this seems like a more expensive way to go when it's easy enough to make your own.
Step 3: Glitter
Add glitter to glue mixture and stir well again. We added about 1 tbs of glitter. You can add more or less, it's completely up to you.
Step 4: Borax
Mix 1/2 tsp of Borax with 1/2 cup of warm water and stir well. Keep in mind, you don't need to pour the entire cup of water into the glue. We've found that starting with a small amount and then adding more if it seems like things are too soft or not combining.
Step 5: Mix
Slowly pour Borax water into the glue and stir as much as you can. Then remove the clumpy mixture from your cup and knead with your hands.
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Does this slime stay sticky for a while, and does it keep its form well? Im trying to find a good recipe for a slime/rubber that cam stick to a wall without drooping or sliding.
