Introduction: Glittered Witch Shoe Candy Dishes
Step 1:
Step 2:
Step 3:
When the paper and glue are completely dry use a fine grade sand paper to smooth out bumps and lumps.
Apply a coat of black acrylic paint to the shoe, I use the paint at full strength. Allow to dry.
Step 4:
With an old paint brush and white glue straight from the bottle paint a layer of glue onto the shoe (not the inside or bottoms) working in sections. You will know if you have enough glue when you can't see the black peeking through. Don't let the glue begin to dry out. Use a spoon to sprinkle with black glitter. Press the glitter lightly into place with the back of the spoon. Keep working in this fashion until the shoe is covered. Leave to dry.
Cut straps and buckles from cereal box board, paint and glitter in the same fashion as the shoe. Paint the buckle with a color as close to the glitter color as possible, this will give it extra pop. Attach the straps with pins dipped in white glue when the pins have dried touch up the pin head with a black marker, it will disappear. Alternately, if the sole of the shoe won't allow you to force pins into it, attach the strap using wire running from the holes in the strap under and across the bottom of the shoe forming a tight sling.
Apply two coats of water-based varnish to the INSIDE of the shoes.
Decorate with these jazzy little glittered spiders (Michaels craft store). Fill the shoe with wrapped candy otherwise the stray bits of glittered might attach themselves to the treats. Enjoy!
For more fun Halloween ideas please visit my blog at: http://lifeartcollide.blogspot.ca
