3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Glittery Raindrop Necklace
  • last photo ←
This Raindrop Necklace would be more glittering in the evening.
And you can use the clasp of necklace as a switch to turn on and off the light.
Step 1You will need
You will need
1 crochet hook
2 blue color of yarn
3 conductive thread
4 5mm LED (white)
5 3V coin cell battery
6 vinyl tape
7 scissors
8 pliers
and needle, necklace clasp
14 comments
Dec 16, 2010. 11:48 AMChrysN says:
I was wondering, do you need a special necklace clasp or would any jewelry clasp work?
Dec 16, 2010. 10:19 PMChrysN says:
Thanks!
Sep 24, 2010. 9:24 PMD00M99 says:
I've always wondered:
Do you shock yourself if you touch the conductive thread with a current running through it, or is it completely safe?
Sep 25, 2010. 6:38 AMCyberscann54 says:
no you wont shock yourself but if you wear it in the shower you might feel a little tingle it will get very nasty if you do that though also long very wet hair may cause .a tingle too,
Sep 26, 2010. 11:48 AMD00M99 says:
Is there any certain reason why you won't shock yourself?
Sep 27, 2010. 6:04 PMD00M99 says:
So you are shocking yourself, just with a really low voltage/watts?. Ok then, thanks! Cause I've seen other projects where your skin is touching a live wire and I'm a bit cautious about that...
Sep 25, 2010. 5:39 AMViaticus says:
It is a very clever design - I didn't read the Instructable thoroughly, but is there a reason to have the battery in a separate ball? Why not have the battery in the tear drop with the LED and run the wires straight up to the clasp?
Using the clasp as a switch is very smart!
Sep 25, 2010. 11:50 PMilldoyourdrugs says:
Very nice job but step 3 and 4 offer no description. I have no idea on how to crochet. That should be included in your instructable. Your leaving out nearly half the projects information.
Sep 24, 2010. 6:20 PMChrysN says:
Beautiful!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:yosyam
