3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Glow Globs - USB Powered Computer Ornaments
Have fun with HOT GLUE and LEDs and make a novel USB powered desk or monitor ornament.
Glow Globs (a.k.a.The Mood Lump) will sit near your computer and endlessly cycle through colour patterns.  (The animations show a sudden change - In reality the change is gradual.)  You could make a couple to brighten up your workspace or give them as presents.  The appeal is such that they're appreciated by anyone - not just computer geeks.  Glow Globs use very few parts and can be made in a couple of hours, although a lot of that time is waiting for hot glue to cool.
There are only a few solder joints to make and these have to be done carefully but the project should be fine for a soldering novice as long as sufficient care is taken.
(I.E. seems to have trouble showing all frames of the animated GIFs, but they work fine with FireFox.)
                                        Light up your life with GLOW GLOBS
Step 1Parts and Tools
Parts and Tools
To make a Glow Glob you will need a USB lead - A dead (computer) mouse is an ideal donor as it has a long, thin and flexible lead.  Anything else with a working USB lead will do though.
You will need a 47R resistor  - That's a yellow - violet - black one.  Quarter watt or half watt is ideal and 1%, 2%, 5% or 10% tolerance is OK.
You need three 5mm slow colour change RGB LEDs.  These look like a normal LED but will cycle slowly through a range of colours when you connect them to a voltage.  These seem quite hard to find from the main suppliers, but there's many for sale via eBay.  Use the search terms "rgb led slow" on your country's eBay site.  Many of these suppliers are based in the far east but I've had no problems ordering items (to the UK) in the past.
You will also need a hot glue gun and normal glue sticks - the ones which are normally translucent, go clear when melted, then go translucent again when cool.
Soldering iron and solder are a must and also a 'helping hands' type tool to hold things whilst soldering.  If your eyesight is anything like mine you will also need your strongest pair of reading glasses.
Finally you need a small area of smooth metal surface and just the tiniest smear of oil or grease - cooking oil is fine.
22 comments
Jun 11, 2011. 2:25 AMvishalapr says:
Cool ible have a look at mine
http://www.instructables.com/id/Remote-Controlled-Arduino-Car/
and
http://www.instructables.com/id/Star-Wars-X-Wing-2/
And vote for them if you like them in the microcontroller contest and the LED contest accordingly
Jun 4, 2010. 12:36 AMgodofal says:
lol, i had olmost exactly the same in mind, its something i made more than a year ago, but didnt want 2 reverse engineer it to make an instructable, when this contest came up, i wanted to make it so i could enter it, but you beat me :D il post some pictures of mine soon. btw, a tip: i think that the overall effect would be even better when you first diffuse the LED's (by sanding for example)
Jun 5, 2010. 9:32 AMgodofal says:
yeah, if i were to make an instructable, i'd have to buy new LEDs, wich would take shipping time etc... im not sure either bout the sanding, but i think it might give an even better effect :D i made some pictures, and a video is being uploaded on youtube.
Jun 15, 2010. 8:42 AMSenior Waffleman says:
i like yours =D
Jun 15, 2010. 10:37 AMgodofal says:
thnx!
Jun 15, 2010. 11:04 AMSenior Waffleman says:
i wanna make one but dont got the stuff D:
Jun 19, 2010. 2:40 AMgodofal says:
its mostly the same stuff like in this instructable, i just didnt have a USB connector handy, so i made one, and i used the diffused plastic of one of those dosing thingies, it was flexible so u can squeeze in it, with a small hole in the tip, it was ment to make those very small pancakes (dunno how they'r called in english :D ) but any diffused plastic thing will work :D
Jun 19, 2010. 10:30 AMSenior Waffleman says:
wat i meant by stuff, is nothing, i dont got led's, or watever that 47R resistor thingy is. so yeaa.......
Jun 21, 2010. 2:02 AMgodofal says:
ah :D well, theyr quite easy to get...
here is an ebay seller that sells 3 superlux (basically the same, just different package) plus resistors, so, when ordering give a comment that you want resistors for 5V, and you should be OK.
one thing though, the OP instructed to  use only 1 resistor for all 3 LED's, but its better to use a single resistor per LED, since they burn down fast if you use them  like that.
just solder a resistor to each LED, and then connect the side of the resistors that isnt connected to the LED's.
if you have any questions,  feel free to contact me ;)
Jun 26, 2010. 9:26 AMgodofal says:
yes, they ARE the right LED's, thos self changing one are called "rainbow" ah, and i forgot about that circutry inside of em, resistor-wise i mean :D but im 100% sure those are the right LED's those superflux have a higher viewing angle, but they always have 4 pins, also the single colour ones.
Jun 29, 2010. 12:16 AMgodofal says:
nope, doesnt work that way, its either 2 pins that are just connected to nothing, or 2 + pins and 2 - pins, that are connected to eachother. and every kind of led comes in those packages, as far as i know. theyr really good for these kind of projects, cuz they have a really wide viewing angle...
Jun 14, 2010. 7:54 AMtechnoguy94 says:
"If your computer shows a message relating to USB port overload then you have a short between positive and negative"... When I shorted the power on my USB port once before, the computer just shut off immediately.
Jun 2, 2010. 3:04 PMweaponzdesign says:
i keep trying to add my entry but its saying that this contest isnt open for entries :/
Jun 4, 2010. 4:48 AMKryptonite says:
The cake competition is a lie!
Jun 3, 2010. 11:12 AMMr.Sanchez says:
What`s going on..?.I cant upload my entry ...Dude ..you`re a winner...
Jun 2, 2010. 2:53 PMTSC says:
Nice!!
Jun 2, 2010. 2:32 PMkcls says:
Ha! Your the first entry in the USB Contest. It's always good to be the first entry in a contest because you get the most views. Nice 'ible, by the way.
Jun 2, 2010. 2:37 PMkcls says:
Apparently over your "Recent comments" page, too! You replied within a minute of my comment! Now that's just embarrassing :D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
122
Author:AndyGadget
