iImage Information
This is an easy modern cube coffee table. You will feel green after you have completed this project. Also the light from the cube will give you an "under 25" look.
Step 1Find a Fish Tank.
iImage Information
This is the easiest, or hardest step. If you need to find a tank, I recommend apartment complexes. Your best odds are at the end of the month. People will usually leave them outside of the dumpsters.
(Note: The term "Dumpster Diving" is offensive. We now use the term "Being green").
Now use cleaner and get all the crud out of the tank.
Layer 2: Design in black contact paper--you don't cover the whole tank, you just cut out shapes or lettering and stick them on.
Layer 3: White paper to diffuse light.
It doesn't make the glass smoother, just smoother than the way some people would try to do it (applying paint/contact paper to the finished tabletop, which is silly.)
Although, after thinking about it awhile...
Wouldn't it be cool to have an aquarium coffee table? :)
Or would that make us look like we are not under 25 years old?
Fish inside a lighted coffee table could be an awesome variation of your design!
Remeber, only you can prevent house fires.... or something like that...
http://www.youtube.com/watch?v=HMh2vnKuLyI - as an example
It was a good idea, though. Maybe if you use a sheet of plexiglass on top to protect it or use some kind of frosted film (available at Home Depot - called window privacy film or at sign stores). That way, if it does break, the film will hold the shards together and won't cause major damage.
Once had a a glass cupboard and banged it shut which broke the glass sending a large sharp piece into the top of my hand - hurt, bled, etc... Not fun.
http://www.youtube.com/watch?v=PgEwEiTyYcs - likely NOT what you will find in the dumpster. Again, just be very careful, yeah?
also a color changing led light bulb would give it a cool effect and make it more efficient
http://www.coolstuffcheap.com/lighttro.html
