Step 7Bright Idea!
Any Cold Light will work.
DON"T USE AN INCONDESSENT BULB. It will get hot, and you are asking for a fire.
I used a Floressent Bulb. 22 for this sized tank.
Use double sided Tape or Hot Glue to mount the light to the center of bottom of the board that you cut earlier.
Turn the light on. After the board is installed you will not be able to flip the switch. Better yet, find a light with a rotating switch on the cord.
Run the cord out of the tank, and close it up.
Remeber, only you can prevent house fires.... or something like that...
