3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Glow in the Dark Light Bulb Night Light (Glo-Bulb)
Step 2Step One: Hollow the Bulb
This step involves glass, some fragile and some broken. Be safe. Do it over your sink or trash, and sweet the area after you are done. You might also consider wearing gloves
One: Using your screwdriver pry up the metal disk on the bottom of the light bulb
Two: Use your pliers to grasp and pull the metal disk off
Three: Break and remove the black glass cone at the bottom of the bulb. To do this seat a corner of your screwdriver in the hole at the bottom of the bulb and tap the end of the screwdriver with your pliers. Once you've broken the cone, use your pliers to break it more and remove the pieces.
(Step Three is a bit tricky. just be careful and take your time)
Four: Break and remove the internal structures of the bulb. Again, use your screwdriver by seating it against the internals and tapping it with your pliers. Then use your pliers again to break up and remove the sharp glass bits.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
44
Author:CYNICALifornia
I'm just another person out there trying to get the most out of life. I love to expole the world around me and try to have a good time doing so.
