FAMILIAR WITH THE RISKS OF WORKING WITH MAINS VOLTAGE
To make this project you will need only few components.
And you could make your own led lamp or decorating light and many more things that you can imagine. This project is just an example to how to build the circuit for glowing led's using 220-250v.
Remove these ads by
Signing UpStep 1: Components Required.
> 4007 Diode (4).
> 250v Polyfilm Capacitor (1) .
> 50v (100 uf) Capacitor (1).
> 1000 m ohm Resistor (1).
> 0.220 k ohm Resistor { should be big in size else the curcit would not work } (1). or something near this value.
Visit Our Store »
Go Pro Today »
The comments here are full of dangerous errors and confusion.
An AC mains mistake can *KILL* you or someone else.
Read this page, which explains the theory properly:
http://www.marcspages.co.uk/tech/6103.htm
25LED
220v and 240v only
e.g 200 ohm 1/2 watt etc what is it's formula
does diode used as bridge can u tell me what is its purpose
read this
http://en.wikipedia.org/wiki/Bridge_rectifier
1> output is 50v - so parallel connection not possible since single LED will carry only 3v [ now since 50 v if i try to connect 16 LEDs in series it shud suffice isnt it 3x16 = 48v] then why in some comments below it is 25 - 30 LED ?
2> if i want to decrease the voltage from 50v to like 12v or less what can be altered and to what amout (since am not into electronics and have least knowledge with not even the basic knowledge of multimeter) if you can suggest the amount and which part i would be glad
3> in your picture above i have seen you have just used 3 leds hw are those able to handle 50v o/p.
4> Now as u specified that circuitry gets a little hot now till how much time can this be left ON.
Tnx a ton for lending time and responding .
This prj is one of my favourite.
I will repeat the parts list agin for clearity R1 = 1 Mega Ohm 1/4 Watt, R2 = 220 Ohm 1 Watt, Capacitor in parrallel to R1= 0.47 Microfarad 450V, Diodes = 1N4007, Capacitor after the bridge is 100 Microfarad 50V.
Its a nice circuit but lot of confusion from your side about it.
KUSHAL
The resistors are mandatory for this Project.
You Cannot Build the project without the Resistors.
i thk its 1/2watt
This is music to my electronics - ears.
If you fear the risk of an electric shock, my advice is to simply use ready LED lights!
Here at home I for example use led spots from LEDoptix;-)
Ya sure you can use red and blue led's.
I intend to make several pieces of 4 LED's as night lights.
Could I ask your help to reconfirm the resistor value (both of them). Also why must you use 50V 100uF capacitor ? Does it mean that you can connect 1 to 17 LED's assuming they are 3V 20mA each?
One last thing, can the LED's be connected in parallel? Advantage/Disadvantage?
Thank you very very much dude!
the bigger resistor is of value 0.218 k ohm (note that when you purchase this resistor it should be big is size than normal resistors).
the 2nd resistor is of value 1000 mili ohm
you can use capacitor according your requirement of the LED's, as you have calculated.
and lastly i would not recommend you to connect the LED's in parallel (disadvantage).
You said its output Dc voltage depends upon the orange capacitor...
How ? if we use a 50 v capacitor then, would its voltage be 50 v..? or so?
Regards.
you could use approx. 30 led's
depending upon which led's you use...
actully I have made one lamp base upon the above mentioned circuit, i want
to make this lamp chargeable.
can anyone help me?
L
but, obiously you should be careful while performing this project.
and thanks for your comment.
