3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Glowing & Flashing Multicolor Devil Duck
I AM GOING TO UPLOAD BETTER PICS ONCE I GET MY NEW CAMERA
Here is a little something for People with a beginning understanding with electronics/soldering, that want an easy project that will attract chicks because, well, its a glowing duck! (And it has horns)
Sorry for the crappy pics but my camera is junk. And has no macro function
But here you can see the duck in the light and turned off.
Then you can see the power on and in the dark.
YOU WILL NEED:
1 a U.V. reactive rubber ducky (I ordered This_one at oznium since it came with a UV LED)
2 Solder Iron/Gun
3 Solder (any size will work)
4 Electrical tape or Heat shrink tubing
5 Wire
6 A switch (I used a toggle but any will work)
7 A battery Holder (optional--can just solder batteries together but once they used up you gotta replace them)-
8 A tri-color/ bi-color /single color LED (I used a tri-color)
Step 1Connecting and Figuring everything out
***Note***
Since this can be such a varied project I am not going into specific detail about how I made mine.
I am going to tell you how to connect everything and some basics about LEDs and Switches.
If you have no idea what an LED is heres a good instructable for you
LEDs for beginners
And if you have no idea how to wire them go here
How to wire LEDs
Blue
UV
Green
White
Purple
These LEDs all run 3.3 volts
Red
Yellow
Orange
These LEDs all run 2.1 Volts
The two LEDs I used were both 3.3 volts so I was able to wire them in a parallel circuit.
Now a diagram if you fall in the same boat as me.....
9 comments
Apr 17, 2007. 9:37 PMdogsrcool2me says:
cough **no current limiting** cough **resister'**'
Apr 18, 2007. 7:21 PMdogsrcool2me says:
I think its still a good idea. The more current you put through a LED the more they tend to draw(the resistance goes down). This leads to a shortened life of the led. It is probably fine though if there is half the voltage of the (on the box) forward voltage across the led, as long as the LED lights.
Apr 17, 2007. 7:22 PMT3h_Muffinator says:
Nice idea! Please retake with either a better camera or in macro mode, I really want to see what this devilishly smashing project looks like!!
Apr 17, 2007. 7:09 AMj626no says:
if your going to get this close, use a macro mode. that is the little flower button. blurry pics like this do no justice.
Apr 17, 2007. 12:20 AMjapala says:
Check our this too:
http://www.ledcalc.com/
Apr 17, 2007. 12:02 AMFrenchCrawler says:
I use the main site:
http://metku.net/index.html?sect=view&n=1&path=mods/ledcalc/index_eng
Which is linked to that site :)
Apr 17, 2007. 12:44 AMjapala says:
Well, yes and no. www.ledcalc.com is based on the new and improved code. I just didn't have the heart to remove the old ledcalc from Metku. :)
Apr 17, 2007. 12:07 AMFrenchCrawler says:
I have way too many Instructables (pictures on my computer) to do, then I have time or energy to do :(
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Radioedit420
