Glowing LED Recycled Water Bottle
Introduction: Glowing LED Recycled Water Bottle
Do you have any spare water bottles? Instead of throwing it away lets recycle it into a glowing lamp that you can drink from!
This is a very simple project for anyone trying to learn electronic projects. Not only will you learn basic electronics, but you will be saving the earth by recycling old used water bottles! Just think how much we can save if everyone was able to do this. If you like this project please vote for it in the green electronics contest.
Please Note
If you would like to see more projects like this, Please Donate Here. If i can get some funding, I have some great ideas for projects.
Step 1: You Will Need
You will need
  1. 2 Water Bottles (any all sturdy kind)
  2. LED
  3. Solder gun/solder
  4. transistor (depending on your LED and power source you may need different kinds) I used 100 ohm
  5. Zinc coated nail/ Foil
  6. Battery
  7. Hot glue gun
Step 2: Cut
Cut out a dish from one of you water bottles about 2/12 inches away from the bottom. This will hold you circuit once its finished.
Try to make the line/cut as straight as possible. To do this, try rolling the bottle against a wall or straight edge while using your marker to draw the line.
Step 3: Sand
The worst part....
Sand both water bottles and LEDs. Now sand them again. Keep sanding them. I had to sand for about 1 hour.
The goal here is when the light hits it, it will create a glowing effect instead of a hard light LED's normally produce.
Step 4: Solder
Now its time to make the circuit!
The circuit is above. Instead of random pictures and symbols that confuse some people, I created a very "simple" circuit diagram.
The positive attaches to the nail or foil piece. On the other nail, the wire is soldered to a resistor then to the LED and back to the negative end of the battery.
Step 5: Test
Touch the two nails together. If they light up, You are doing good so far!
It works because the nails or foil pieces work as a switch, when they are not touching the electricity cant flow.
Once they touch the electricity can flow again and the LED lights up
Step 6: Glue in Place
Using Hot glue, Glue your circuit in place. The two nails should go through the bottom and into the uncut water bottle.
Using hot glue, seal the hole so its watertight. Place your circuit into the dish you cut and firmly press the water bottle into it.
Step 7: DONE
Your Done!
Now when water is added into the bottle, The circuit completes and your water bottle lights up!
Take this with you and show your friends your new Glowing LED Recycled Water Bottle. (Its safe to drink if the batteries are not too strong)
Please vote if you enjoyed this instructable
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Epilog Challenge 9
      Epilog Challenge 9
