Supplies you'll need:
•Large Carving Pumpkin (Mine's about 13" tall)
•Knife/Carving Tools
•Standard Lightbulb Sockets with Wiring & Wall Plug (I used 3)
•A Lightbulb for Each Socket (I used 40W, but those are MUCH too bright!!)
•Permanent Marker
Decorating Supplies: (Optional)
•Heavy Gauge Wire (I used 12ga)
•One Small Potato
•Spray Paint
•Bouquet Pearls (I used 6)
•Toothpicks
•Two Cotton Balls
Remove these ads by
Signing UpStep 1DIG IN!! Carve up your pumpkin!
Cut a hole in the top around the stem. Be sure to angle your cuts inward so as your pumpkin dries it wont cause your "lid" to fall down inside the body of the pumpkin. Also make sure you leave a notch in your circle so you can easily tell how the "lid" is supposed to fit -- for future reference.
Clean out all the innards and be sure to use a spoon or pumpkin scraper to get alllllllllll the gooeyness out of the pumpkin. You want the inside to be very solid and as dry as possible!
Next, cut out the mouth. I went with a basic semi-circle mouth as not to detract from all my pumpkin's crazy headgear! This will give you a second access hole and will make the smaller holes MUCH easier to cut. (And also, the simpler the shape of the mouth, the less you'll have to worry about accidentally knocking off a tooth or something as your banging around inside your pumpkin!)
Then cut the eye socket holes. I unscrewed the assembly for my lightbulbs and used the top of it to measure my hole. (Be sure the holes are far enough apart for the large end of the lightbulbs not to be bumping together!)
Finally, cut an access hole in the top back of the pumpkin for your wires. I also made mine big enough to hold the socket for the bulb that will light the inside of the pumpkin itself as a candle wont be an option because of my sockets and wiring inside the pumpkin.
comments
Add Comment
vishalapr
says:
ChrysN
says:
Add Comment
