Boy, have I got a great project for you!
We will take a beautiful plastic box, which is otherwise destined for the landfill, and turn it into a powerful room accent.
While the component dimensions are developed for the particular box which I used, the project is simple enough to be easily adaptable to other sizes of boxes.
If you have a box that is coloured and has some graphic decoration, then it is a good candidate for this project.
Go for it!
Remove these ads by
Signing UpStep 1Yay! A short materials list!
1. Low-wattage lighting components: I recommend a "PL" type of compact fluorescent bulb. This example uses a PL-18 (18 watts). Lower wattage systems are available; they use shorter bulbs which would be appropriate for shorter boxes.
Source: a specialized electrical supply store ought to be able to outfit you with bulbs, socket, and ballast. DON'T leave the supply store without a ballast/socket/power wiring diagram!
2. Other electrical components are:
-two-wire cord
-two prong plug
-switch
-twist wire connectors
Source: most hardware stores.
3. A small piece of plywood, Masonite, MDF, at least 1/4 inch thick.
Sources: your scrap bin, your neighbour's scrap bin, the dumpster down the street...
4. Wood screws:
-#4 x 3/8 inch long
-#8 x 1 3/4 inch long
(Please don't obsess about these specifications, many other sizes will work but this is what I used)
Sources: your spare screw jar, the hardware store if you are not a pack rat
NOTE: The box I used is approximately 3.5 inches square and 12.75 inches tall; my light assembly is 10.75 inches tall using the PL-18 bulb.
The PL bulbs are available in a whole range of wattages and sizes.
For instance, using the PL-5 bulb would result in an assembly 7 to 8 inches tall, and the ballast is smaller. So this would suit shorter and narrower boxes.
10
comments
Add Comment
lemonie
says:
lemonie
says:
lemonie
says:
Add Comment
