3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Glowing video tape USB hub
Step 2Open the tape
Open the tape
Make sure, there's nothing recorded on the tape you want to keep, because this mod will destroy it...
Not this step, but some of the following steps will do so...
Take your tape, flip it around and take a look at the underside of it:
Do you see these screws? Grab your screwdriver and get them out of there, but don't lose them, ok?
Now pick up the tape and turn it around so the topside is up again, make sure to hold it together, so it can't seperate while you turn it, otherwise the reels may fall out and all the tape would unroll, and that's bad mkay?
Gently pull the cover off, if the flap which normaly protects the tape comes off, too, don't worry it's easy to put it back on, we won't even need the small spring later...
2 comments
May 4, 2008. 9:03 PMduckcrazy says:
The centre hold is the release of the stopper. if the tape got stuck and films is pull out, press the hold with a stic and you can roll the wheels by your thumb easily.
May 1, 2008. 10:58 PMaditya_t90 says:
He he What's a srew? Just jokkin gr8 work
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:HarryM
