Introduction: Glucose Meter Case AND Wallet
Picture of Glucose Meter Case AND Wallet
It's all to easy to forget my glucose meter when I leave the house, or misplace it altogether. By creating a system to house my glucose meter supplies, my credit cards and IDs, AND my smart phone if need be, I have drastically reduced the number of times I lose my supplies! Stylish and practical, I'm very proud of this project! I hope you enjoy it too.
For other projects similar to this, please visit my blog: Diabetic Hacker
Step 1: Gather Materials
Picture of Gather Materials
  • 3 coordinating fabrics. I've used fat quarters and there is PLENTY of fabric. It really doesn't take much!
  • Old Jeans (you can use interface, but I've found that jeans give it a really nice weight and durable feel)
  • 9" zipper
  • Bias tape (size and # of folds aren't super important)
  • Magnetic Purse Snap
  • Sheet Protectors (there are lots of options here. You can get the actual transparent material supplies from craft stores, I just tried to use what I had at hand. I've also used zippered sandwich bags - however that doesn't hold up quite as well)
  • Meter case that came with meter (not pictured)
  • Lace (Optional)
  • A supervisor is always helpful to keep you on track and judge you when you don't iron your fabric
A Few Notes:
  • Unless stated otherwise, I use a 1/4" seam
  • IRONING IS YOUR FRIEND - it will make a world of difference in how professional your clutch turns out. Iron your fabric often, and then again.
Step 2: Cut Jeans and Fabric
Picture of Cut Jeans and Fabric
  • Outside of case: 9" x 12" (I would actually make this 9" x 14" if I was to do this again) of outside fabric and jeans
  • Card Pockets: 9" x 12" (I would actually make this 9" x 14" if I was to do this again) of cash side fabric
  • Pockets: 9" x 8 1/2" meter-side fabric (cut 2); 9" x 4 1/4" jeans (height mislabeled in this picture, use 4 1/4, not 4 1/2) (cut 2).
  • Cash Side Background: 9" x 12" (I would actually make this 9" x 14" if I was to do this again) of cash side fabric and jeans
  • Meter case side: 9" x 8 3/4" of meter side fabric and jeans
Step 3: Assemble Main Pockets
Picture of Assemble Main Pockets
There are two pockets, one will be zippered for things like coins, the other side will be an open pocket for things such as cash and checks. Let's start with the zippered side.
  • Take one of the pockets you cut in step one (both the fabric and the jeans) and the zipper. First, place the zipper along the top edge of the fabric, teeth facing towards the end of the fabric. Fold the fabric in half length-wise, RIGHT SIDES TOGETHER (sandwiching the zipper). Place over the jeans (they should be the same size) and pin
  • Take a moment to evaluate you have all the items properly aligned. It is a good idea to have your supervisor check it out for you too.
  • Trim the outer edges (including the zipper tail - although be sure the zipper pull is not cut off in this step!).
  • Now let's do the other pocket. Fold the fabric right sides together and place on top of jeans. Pin and sew.
  • Turn both pockets right side out and iron
Step 4: Sew Card Slot Pockets
Picture of Sew Card Slot Pockets
  • Take the card pocket fabric and hem top and bottom (the narrow edges of the rectangle)
  • This is one of those steps I kind of "winged it' on, but this is how I should have done it. Pin or mark the fabric at the following measurements: 1/2" from the top, 2 1/2" from top, 4 1/2" from top, 5" from top, 7" from top, 9 1/2" from top, so something like the diagram above.
  • Now we can fold at these points in an accordion style to make the card slots - blow by blow: Fold 2 1/2" pins to the 1/2" pins (pin this fold), Next, fold the 7" to the 5" markers and pin. You should see something like the 4th (?) picture above.
  • Ok, if you've made it to this point, it's all downhill from here, I promise! We're going to attach this to the pocket from step 2 that does not have the zipper. Pin it 1/2" down from the top of the pocket
  • Sew down the sides, bottom and down the middle.
Step 5: Construct Window Pockets
Picture of Construct Window Pockets
  • Measure and mark a 9" x 3 1/2" rectangle from the sheet protector. I like to use the edge/corners so that it's actually a double layer.
  • Cut it out!
  • Sew bias tape down the middle
  • (Optional) Place lace along the top
  • Sew bias tape along the top to make it finished
  • Put windows over zippered pocket and stitch down the center and along the bottom. I used the edge of the page protector along the bottom, so it's already "finished", just need to stitch along the bottom.
Step 6: Put the Guts Together
Picture of Put the Guts Together
  • Let's start with the zipper. Align the other side of the zipper (the one that's not sewed to the pocket) to the top edge of the right side of the cash side fabric. Place over jeans (first image)
  • Place right side of meter side fabric and jeans to the right side of the cash side along the zipper (the window pockets should be sandwiched). Stitch along the zipper edge. (second image)
  • Open it up and it looks like the third image!
  • Now let's attach that other pocket. Place it parallel to the windowed pockets in the opposite direction. It doesn't quite touch the window pocket. Stitch the bottom
  • Fold the meter side over the cash side (it should fold along the zipper with right sides together). Mark the bottom of the window pockets with pins
  • Stitch from the zipper to the pins on both sides. Turn inside out. You now have a zippered pocket!
Step 7: Install Male Magnetic Clasp
Picture of Install Male Magnetic Clasp
Above the Cash Pocket is the top flap. We put the male clasp here. Follow installation instructions on clasp package (install through both the fabric and jeans layers)
Step 8: Put It All (Well Mostly) Together
Picture of Put It All (Well Mostly) Together
  • Pin the right sides together of the outside fabric and the cash/meter side - the zippered pocket just kind of is sandwiched in the middle for now.
  • Now stitch around 3 of the edges, leaving the bottom (non-zippered edge of meter side). Turn inside out and top stitch the top flap (the flap with the male magnetic clasp)
Step 9: Install Female Magnetic Clasp
Picture of Install Female Magnetic Clasp
At this point, hopefully you can fold the billfold together and see where the female clasp should go. Install according to the instructions (again, remember to go through the fabric AND the jeans)
Step 10: Close the Open Edge
Picture of Close the Open Edge
Not going to lie to you here, there are much better ways to finish off your clutch - but I can be lazy sometimes and this seemed the easiest way. Fold in the unfinished edges in and stitch along that top.
Step 11: SO CLOSE TO THE END. Install the Meter Components
Picture of SO CLOSE TO THE END. Install the Meter Components
Mostly, it was just a question of gutting the case and either stitching the elastic or gluing the rubber meter holder (again, probably could've done this a more sophisticated way, but super glue has worked superbly and so easy).
  • First, with a seam ripper, pull the elastic and rubber meter holder from the case
  • Now attach the new components to the meter side in whatever arrangement you like! I hand stitched the elastics and glued the holder, but I'm sure you can figure out whatever you need to do.
  • You can be done here if you want but of course, after all this effort you may want to ...
Step 12: Personalize and Make It Your Own!
Picture of Personalize and Make It Your Own!
There is a nice canvas on the back of the wallet to decorate however you want. Embroidery is always fun. For this case, I was feeling pretty "Wonderful" and decided to roll with it. I intend to stitch the inside lines of the W, as well as add a small star in the front... but it's fully functional and I hope I've given you everything you need to make your own!
About This Instructable
1,233views
2favorites
License:
More by Diabetic-Hacker:Insulin Pump ShortsAnother Insulin Pump CaseGlucose Meter Case AND wallet
Add instructable to:
