Glueless PVC joints that stay stuck together but can be taken apart in seconds!
 by MechanicalMashup
Featured
I love PVC pipe and tubing.  You can build awesome projects with it like Trebuchets, Steady cam systems, Light stands, Green houses, and tons more. Its a grownups (and kids) big erector set. But some things are too big to glue together so you want to disassemble them. Problem is sometimes your project just wont stay together without some glue. Using PVC glue is messy and smelly.
Now some have asked why I did not just buy some metal spring pins or clevis pins. There are a few reasons. Metal on plastic tends to wear down the plastic and make sloppy joints. The metal spring pins are too tough to push into a tight fitting hole and hard to drill to add a key ring. Plus you can make hundreds of these for pennies where as hardware can end up costing you a lot more money.
Here is my quick, easy, cheap and light solution to this problem:
(the next steps show you what I show you in the video below)
Step 1: First gather your supplies
You will need:
  • Key rings, you can get 50 for a couple bucks at a stationary store
  • 1/4" poly tubing. You can get 25' of this at a hardware store for less than 5 bucks
Tools:
  • Drill
  • 1/16" drill bit
  • 3/32" drill bit
  • Utility or hobby knife
  • Pencil sharpener
Ogredude says: Jan 16, 2013. 6:29 PM
This is fantastic! This technique will surely see some use in the fan-run convention I help out with. We build lots of stuff out of PVC.
jtong77 says: Feb 7, 2013. 7:49 PM
This is brilliant. Thanks for sharing!
sparkleponytx says: Jan 27, 2013. 11:55 AM
Cool!
DennisTheBald says: Jan 17, 2013. 3:00 PM
That's nice. The key ring doesn't seem to add much tho. Make the circle of wire bigger, then fold it in half like a taco, with the one end of the fold right through the end of the plug. Then, after you push the pin through the two pipes you can hook the loose end of the wire taco over the other end of the pin and kinda lock it in place, like the metal "grenade" pins they sell at the hardware store.
Dream Dragon says: Jan 16, 2013. 10:30 AM
Love this idea! I'd like to see some projects that use this system.
MechanicalMashup (author) in reply to Dream DragonJan 16, 2013. 10:41 AM
The projects using these are coming soon :) thanks for the pat on the back!
momm says: Jan 16, 2013. 5:27 AM
great idea, love the idea of functional easy erecter-ible objects. thank you.
technovative says: Jan 15, 2013. 8:02 PM
Interesting alternative to using screws to fasten PVC pipe and fittings together.
MechanicalMashup (author) in reply to technovativeJan 15, 2013. 8:07 PM
Ya I tried screws and wanted something for a faster tear down, that did not take any power tools and did not slowly make for lose joints. You can also carry these in your pocket and not worry about being stabbed in the leg from a screw :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
