I got almost everything here for cheap or free, or from a swapmeet.
Say goodbye to making gliding motions in order to skate - now you can stand still and watch the scenery pass you by!
Check out Go-llerblades Part 2 also.
Remove these ads by
Signing UpStep 1Angle Grinder
Take off the guard plate (if yours has one) with a screwdriver.
the video is in part deux
http://www.instructables.com/id/Go-llerblades%3a-Motorized-Skates---Part-2/
did you mean, "a while ago, I bought [something] to change 12v-20v dc to ac.. "?
Your laptop runs on DC, and yeah, converting AC to DC is called inverting.
See this.
Think about it. See why it makes sense?
12v DC to 20v DC as you originally stated it actually is ( in electronic/electrical terminology) a voltage converter.
Inverter -> DC ->AC
Voltage Converter : V ( AC or DC ) to different V ( same AC or DC )
The opposite of an inverter is usually a transformer coupled with a rectifier ( usually a bridge diode one ) to convert the AC to a usable current by the appliance.
You actually might have saved yourself money by getting a voltage converter kit from an electronics store to convert your vehicles unregulated 12VDC supply into a regulated V (whatever your laptop V supply is ( the same as the battery pack in it )) DC, but it would have the drawback of being restricted to powering only devices that operate on the same supply. Whereas your inverter can power many devices.
The main reason we generate AC is to supply power over long distance via power lines 99% of the time it is converted to DC on arrival. So to use a an inverter to convert a DC supply to AC to convert it back to DC over a short distance is redundant. Before you ask it IS possible to power some AC devices
with straight DC (not all) it is dependent on their supply circuitry. Check out the history of AC/DC ( currents not the band (sorry bad pun)).
please dont take any offence at anything I've said but as an electronics/telecommunications technician and electrician with over 15yrs experience I only wanted to correct these point and hopefully point you in the right direction research wise. best wishes.
PS staterisk love the ible.. very creative (like most of yours) remind me of the jefferson's when are we going to see the jet powered skateboard? (oops! shouldn't give away ideas so freely, damn!)
