3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Go-llerblades: Motorized Skates - Part 1
Take a bunch of common parts, and create the hottest set of wheels around.
I got almost everything here for cheap or free, or from a swapmeet.
Say goodbye to making gliding motions in order to skate - now you can stand still and watch the scenery pass you by!
Check out Go-llerblades Part 2 also.
Step 1Angle Grinder
Angle Grinder
I got this one at a swapmeet for $9.
Take off the guard plate (if yours has one) with a screwdriver.
56 comments
1-40 of 56next »
Dec 17, 2011. 4:12 AMFrozenIce says:
hahaha soo random :)
Dec 16, 2011. 2:03 PMbonestock says:
Why not turn the grinder around and affix it in a manner where you can fasten the grinder to spin one of the wheels?
Dec 16, 2011. 7:36 AMraith2006 says:
I can't see this getting very good speed, what have you been able to get up to?
Jul 24, 2010. 8:24 PMbillbobaggens says:
(removed by author or community request)
Dec 14, 2011. 8:44 PMsensoryhouse says:
flagged
Aug 1, 2011. 8:52 AMleon0862 says:
thank you for saving me the time to type that
Oct 5, 2011. 7:52 AMnerd12 says:
agreed you should use a proper wheel. the brush is in effective. it would also result in a turning effect.
Dec 14, 2011. 5:00 PMnerd12 says:
something with high rpm should use some heavy duty wheels. certainly not plain plastic.
Dec 14, 2011. 8:07 AMtrf says:
Id turn the guard around if I were you buddy. When those wire wheels wear down, they tend to throw off the bristles like needles. They WILL go through a pair of plain jeans and stick in you! Been there and done it, I use one quite often. They will penetrate heavy work pants too.
Dec 14, 2011. 5:03 PMcincymikeb says:
Im with TRF on this one, been there done that . had one wire stuck in my lip Even worse fling a couple wires at some bystander and things could get expensive real quick .
Dec 14, 2011. 5:05 PMcincymikeb says:
You'll put your eye out kid !
Aug 3, 2008. 9:19 AMthe_burrito_master says:
wouldn't you sorta go in circles and is it hard to control? otherwise nice.
May 12, 2010. 3:56 PMTSC says:
Nice !!!!!!!!!!!!!!!!!!!!!!
Jan 17, 2010. 1:54 AMsharlston says:
hey thats good but how fast does it go?
Aug 22, 2008. 8:39 PMneardood says:
That looks EXTREMELY dangerous. Also, would'nt the batteries be very hard to carry? Even so, please post a video.
Apr 10, 2008. 12:26 PMJAKEjones1 says:
sweet idea duz it realy work good?''and is it fast enough or shuld i get two grinders and have a reserve/booster one? nice instructable! oh and... how fast duz it go in m.p.h?
Nov 29, 2007. 10:02 AMjuggalo_assassin183 says:
instead of 5 battery's why not just one battery and a small power inverter like you plug into you power point into your car to charge your laptop that would greatly reduce the weight
Nov 30, 2007. 8:21 AMjuggalo_assassin183 says:
a while ago I bot a deal to cane 12v-20v dc to ac for my laptop on a road trip and it was called a inverter
Dec 5, 2007. 7:40 AMjuggalo_assassin183 says:
i just know that it was called a inverter and it changed dc to ac it had 2 120 outlets on it and conected to our power point in the car so i could plug my wall charger into it like this thing here
Sep 19, 2011. 6:31 AMFenrisLokison says:
Dude you are correct in calling it an inverter if it converted 12v DC to 120v AC, which from this response of yours to stasterisk seems to indicate, but if it converts
12v DC to 20v DC as you originally stated it actually is ( in electronic/electrical terminology) a voltage converter.
Inverter -> DC ->AC
Voltage Converter : V ( AC or DC ) to different V ( same AC or DC )
The opposite of an inverter is usually a transformer coupled with a rectifier ( usually a bridge diode one ) to convert the AC to a usable current by the appliance.
You actually might have saved yourself money by getting a voltage converter kit from an electronics store to convert your vehicles unregulated 12VDC supply into a regulated V (whatever your laptop V supply is ( the same as the battery pack in it )) DC, but it would have the drawback of being restricted to powering only devices that operate on the same supply. Whereas your inverter can power many devices.
The main reason we generate AC is to supply power over long distance via power lines 99% of the time it is converted to DC on arrival. So to use a an inverter to convert a DC supply to AC to convert it back to DC over a short distance is redundant. Before you ask it IS possible to power some AC devices
with straight DC (not all) it is dependent on their supply circuitry. Check out the history of AC/DC ( currents not the band (sorry bad pun)).
please dont take any offence at anything I've said but as an electronics/telecommunications technician and electrician with over 15yrs experience I only wanted to correct these point and hopefully point you in the right direction research wise. best wishes.
PS staterisk love the ible.. very creative (like most of yours) remind me of the jefferson's when are we going to see the jet powered skateboard? (oops! shouldn't give away ideas so freely, damn!)
Nov 19, 2007. 8:20 PMqwerty90210 says:
i the right kind of stupid to do this while not being able to use roller blades AWESOME
Oct 31, 2007. 5:10 AMthepaul1993 says:
all i have to say is WTF
Sep 21, 2007. 3:33 PMstarisanass says:
Sep 22, 2007. 7:20 PMNachoMahma says:
> shows how immature, idiotic and stupid you are . And your response certainly indicates a high level of intelligence and maturity. ;)
Sep 22, 2007. 6:35 AMrobin_lefay says:
starisanass: You stupid stupid stupid man. You think it was on purpose? Why?
Aug 28, 2007. 3:46 PMjfc443 says:
has potential however i dont really fancy carrying round 5 huge ass batteries. could use a transformer or something surly. and wireless would b awesome. but still cool idea tho and has probly given insperation to quite a few people nice 1
Aug 27, 2007. 7:00 PMZo1x says:
hahah i can just picture the person going in a circle because its only on one wheel, dude,Do it to both wheels,that would like like crazy.
Aug 21, 2007. 9:00 PMWard_Nox says:
1 step closer to Air Treks
Aug 17, 2007. 11:12 PMtomfoolery says:
I have a idea! (amazing isnt it?) Costom build two, thats right, TWO skates with builtin motors, brakes, baterypacks and wireless controll curcutry. Then build a remote. If you press the left button, the right skate sppeds and the left slows. The brake button would controll the brakes, ect. you get the idea. I would love to build this new idea of mine but im 13. While I do understand the technical aspect of it all, implementation is a big problem. Someone please build it! Btw, nice instructable. But the engeneering is very poor... duct tape? Are you serious?
Aug 20, 2007. 5:12 PMtomfoolery says:
Well, who says you have to use 4? 2 would be sufficient and I think there would be a better motor choice, because are angle grinders real that enegy efficient? im sure you could use less baterys with a different motor. and ill bet the wiring wouldnt be hard...
Aug 20, 2007. 8:13 PMtomfoolery says:
First, it wouldn't take much engenering to use just 2 and have reverse abilitys. and it would lighten the batery load. and secondly, you would have alot more speed or power if you build your own gear box, but everyone's resources are limited so.. lastly, couldent you attach the angle grinder (or other motor) directly to the weel of the skate?
Aug 2, 2007. 3:13 PMhondagofast says:
By doing this you have joined the ranks of completely f**king lazy people.
1-40 of 56next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
199
Author:stasterisk
Hi! I'm Star Simpson! I'm a real me! See more at [http://stars.mit.edu stars.mit.edu]. photo by [http://bea.st/ Jeff Lieberman] (http://bea.st) stasterisk - my name is Star, and when I wa...
more »
