GoPro Gravity Slider
Introduction: GoPro Gravity Slider
The GoPro Gravity Slider is a custom mount for a GoPro that allows it to shoot footage of an object as it is falling. If you drop the object and the GoPro at the same time, you'll see the whole fall down to the bottom. Then the object will splash or splat or break in some other way.
Or just watch the video below and you'll see what I mean.
Step 1: Stuff!
  1. plank of wood. This one is 6'
  2. 2 metal rods
  3. Afinia H-Series 3D Printer
  4. GoPro HERO3 camera
  5. wood screws
  6. rubber spacers
Step 2: Printed Parts
There are three pieces for the slider. The two blue pieces were printed on an Afinia 3D Printer and hold the rods in place. The middle piece was printed on an Objet printer, but could've been printed on an Afinia as well.
If you don't have a 3D printer, you can easily make these pieces with some scrap wood and a drill press. Instead of the custom GoPro mount that's automatically included, you can attach a regular GoPro mount onto the wood with the included adhesive.
STL files are included below.
Step 3: Attach First End Cap
The caps are easily attached. Here's the process:
  1. drill pilot holes
  2. place rubber spacers over holes
  3. attach cap with wood screws
Step 4: Attach Second End Cap
Attaching the second end cap is just as easy. For alignment, insert the rods before you attach them.
Step 5: Attach Slider
Now that the rods and caps are in place, put the slider mount on the rods. Once it's on you can insert the rods into the bottom mount.
Step 6: Attach the GoPro
Now it's time to put the GoPro on. Just slide the case with the GoPro in it onto the printed mount and insert the screw for it.
Once that's on, put some padding behind the case and secure the GoPro to the slider with some tape. Here I'm using two small strips of Gorilla tape. This last step helps to keep the camera from rotating on the mount on impact.
Step 7: Pad the Bottom
To soften the landing, I wrapped some tissues around the bottom of the rods. This helps to reduce the camera bouncing back up after it lands. It's an OK solution, but there's still a little bit of a wiggle when the camera hits the bottom. This is where I'm going to keep working on it for future versions, but for now the footage is coming out well enough for most shots. The slight wiggle at landing helps to accentuate the impact, but it's not the best.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    Hi, I don't seem to be able to find the stl file for this, can you please upload it?
    is it possible to order/buy these plastic custom parts ?
    You can go on and upload the files there.
    Super idea.
    Just got my GoPro :-)
    you could use a custom set of springs to reduse bounce
    The GoPro is [kinetic] shock proof, so you don't need to protect it against that. If the goal is to eliminate the bounce, that is a solved industrial requirement. You could:
    1. Use sand to deaden the blow similar to a Dead Blow Hammer
    2. Place very strong Neodymium Magnets on the mount slider and the bottom of the support system.
    There are many ways you could implement either of of those. Since you have a 3D printer, you could reprint the sliding mount to hold a rod that extends out the bottom. Then place the rig above a bucket of sand. When the rod hits the sand it will sink a little, but will not bounce. You could even use different diameter (or taper) rods to cause it to sink farther giving a slower stop.
    I made some mockups of what this modification may look like.
    you should look at putting a soft close draw actuator on the landing, needs something to reduce the sudden impact of the footage
