3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
"Godzilla" the Giant Sparkleball
Step 5Putting the pieces together
So, you've got these two half's of a sparkelball laying there, connected by wires, and looking very much like an autopsy gone bad.
Now, take one half of the sparkleball, turning it over, and placing it on top of the other half. Since you used the same number of cups per half on the base circle, they will sit nicely on top of each other. This is where the large plastic tub comes into effect.
Since Godzilla was 32" across, all the weight (25 pounds) would be sitting on just a handful (two or three) plastic cups on the bottom of the Sparkleball. So, I placed the first half upside down on the tub, which gives good support around the ball. Placing it on the tub also gives me the ability to easily turn the ball around without damage, and keeps me from having to walk around and around it multiple times to make welds, connections, or whatever finishing touches I needed to do.
Next, use your clothes pins, and clip together every cup and every connection around the sparkelball where the two halves touch, get out your Soldering Iron, and start the final assembly (welding) of your sparkelball. Every place the plastic touches another cup, weld it.
Do not force the connections, as they will weaken, or even crack the cups.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:vwluvrs
