3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Golf Ball Gun!!! How To Make One That Can Shoot 400+ yards!
  • C:\Program Files\My Shit\Spud Stuff\My Stuff\My Guns\SG Assault\SGA Over-View.JPG
  • C:\Program Files\My Shit\Spud Stuff\My Stuff\My Guns\SG Assault\Piston.JPG
  • C:\Program Files\My Shit\Spud Stuff\My Stuff\My Guns\SG Assault\Close Up.JPG
  • C:\Program Files\My Shit\Spud Stuff\My Stuff\My Guns\SG Assault\Pilot Setup.JPG
  • C:\Program Files\My Shit\Spud Stuff\My Stuff\My Guns\SG Assault\Tee Housing.JPG
  • C:\Program Files\My Shit\Spud Stuff\My Stuff\My Guns\SG Assault\Sealing Face.JPG
New, better instructable:
http://www.instructables.com/id/GolfballAntennaNerf-Cannon---Build-One-That-Shoo/
New, better video:
http://nz.youtube.com/watch?v=pkejntZlQC0
Youtube Channel:
www.youtube.com/PerformanceCannons
This is my golfball gun, it features a 2" barrel sealing piston with 1.5" porting. The chamber is made from 2" Pressure Rated PVC pipe and the barrel is 1.5" PVC pipe. For more information go to:
http://www.spudfiles.com/forums/viewtopic,p,100616.html#100616
Big Thanks to Nicholas Benigni, owner of SpudGunExtreme.com
You can find his website and spudgun products here:
http://www.spudgunextreme.com/
Note: In the video I am wearing safety glasses you just can't see me, the shot at the end without them is perfectly safe as I was only firing air.
I also have more then enough objects as a back stop to make certain the projectile doesn't go all the way.
One shot I am firing into the open, I was shooting a golfball 380m at a golf course that was closed due to weather 50m away.
You may need to use some Lube to help the piston slide easier:
http://www.amazon.com/Astroglide-Personal-Lubricant-Water-Based/dp/B000CLTYCW/ref=pd_bbs_1/103-7975610-3340617?ie=UTF8&s=hpc&qid=1189202562&sr=8-1
Step 1How it works:
How it works:
1) Air is sent through the inlet valve, this pushes the piston(green) forward and sealing the barrel, the air leaks around the chamber and fills the chamber up.
2) Once the air is equalized all around the chamber and valve, the inlet valve is closed.
3) When you want to fire, you open the pilot valve and all the air behind the piston(pilot area) vents out this valve, since the pressure on the piston is un-equalized with more pressure at the front pushing it back, then pushing it forward the piston actuates.
4) The piston flies back at incredible speed and all the air goes out the barrel and launches the projectile.
That's how simple it is.
293 comments
1-40 of 293next »
Jul 11, 2011. 8:34 AMTorturdChaos says:
A friend and I built one similar to this - using a sprinkler valve as a trigger tho. For a piston we used a piece of exhaust pipe with 2 round plats welded to each end. Used some sheets of gasket and such to make seals and bumpers for the ends.
We setup a ballistics pendulum to try to get a reading on the speed of a golf ball and after breaking several of them we finally got something around 700ft/sec for a muzzle velocity. Our measuring whole setup was overly accurate, but I willing to say were in +/- 60ft/sec, which still puts that golf ball going really freaken fast (something like 400-500MPH)
Mar 6, 2011. 2:42 PMdanjo62 says:
how much psi would you pump it up to if you wanted the golfball to shoot 400 yards like you said?
May 5, 2010. 5:54 PMtomtortoise says:
I was wondering what kind of can is the best for this like a specific brand or something. i was also wondering how much this costs about for a basic version?
May 15, 2010. 10:00 PMJamesTrick says:
 I'm live in NZ and am just wondering what type of can you used. Or would a coke can work?
May 7, 2010. 6:00 PMtomtortoise says:
thanks. but also how do you attach the valves to the end cap on the back of the piston valve. i could use reducers to get it down to 1/2 inch but is there an easier way
Feb 21, 2010. 1:25 PMaudio8448 says:
can you buy the 1.5" sdr21 pvc pipe at home depot or lowes?
Apr 24, 2010. 7:12 AMclemsonguy1125 says:
 No
Apr 25, 2010. 9:51 AMclemsonguy1125 says:
 I can get mine locally but I have to go to a plumbers supply store, the have a giant scrap pile and sold me 8 feet for 75 cents
Apr 1, 2010. 9:44 AMMusicman41 says:
I was trying to watch your animation, but I found it difficult to take in everything displayed.  It would be much better if you showed it in multiple pictures or had a button on the picture to advance the stages more slowly.  Just a suggestion. :)
Apr 15, 2010. 4:36 PMMusicman41 says:
Ah I see now.  That helps a lot!!  Thank You!
Feb 21, 2010. 7:17 PMknex luver123 says:
oops i said that in my friends login, he came over and we got on, he is cboyer123, so that was me.
Feb 21, 2010. 7:12 PMcboyer123 says:
no prob, now this was only at my local lowes, and your local lowes might not have the 1.5" sdr21 pvc piping, so dont get mad if it isn't there, but yes, only trustowes piping, my friend said his home depot one blew apart, so i built two of the same canoon (simple bal valve) with the same sch, and the home depot one blew up, and the lowes one owned, so i only trustlowes pipe.
Feb 21, 2010. 6:06 PMaudio8448 says:
 thanks knex luver123! i have an air cannon that i should be able to make another barrel for using the sdr21 pipe
Feb 21, 2010. 4:42 PMknex luver123 says:
cuz iv dun it accesable with the deodereant one, and never needed yo acessit, and i think after 20 minutes i lose some air, and would like the maxikum amount of air for the bird removal.
Feb 21, 2010. 4:09 PMknex luver123 says:
oh and Mrcrowley, with the qwooden piston from your other cannon, do you still need the piston housing to be accessable?
Feb 21, 2010. 4:05 PMknex luver123 says:
audio8448, i foud it in my local lowes, and didn't really find what i wanted at all at home depot, and lowes piping is way better quality, if this will help at all.
Feb 20, 2010. 7:05 PMknex luver123 says:
i made it completily out of metal, and shoot it at 300 psi, and shot the ball, well i dont know, i never found the ball, but i am guessing around 600 yards. and then a custom (homemade lead slug) through 6 sheats of plywood!!!!!
Jan 8, 2010. 8:05 PMpablorox says:
How much did This gun cost?
Aug 28, 2009. 7:45 PMbombmaker2 says:
those poor melons
Aug 20, 2008. 6:15 PMcowscankill says:
im confused how this works. i wish you could make slightly better instructions, or more pictures of the inside.
it looks great, but i doubt i could make it right without better instructions. thats just how my brain works :/
Jul 23, 2009. 8:02 PMakatsuki666 says:
use his otyher instructable same thing just ignore the cartoon on the other one
Nov 27, 2008. 10:58 PMbiggy smalls says:
i agree as well, shallow and pedantic
Jun 5, 2009. 5:35 AMGBG77 says:
Where can u find all of the materials????
May 2, 2009. 9:15 PMSpeedmite says:
STEREOTYPER!!!!! I have never shot anyone with anything remotely dangerous excluding myself.
Nov 28, 2008. 9:32 PMbiggy smalls says:
that was a reference to "family guy". but the point was that this instructable is not as easy to understand as the new one.
Jul 23, 2009. 4:33 PMakatsuki666 says:
no offence but this explains it much much better than ur other 1
Jul 2, 2009. 6:04 PMColonel88 says:
I agree. The instructable is not so good, but the result is awesome. maybe better illustrations?
May 30, 2009. 7:54 PMaflacgoose says:
Amazing design!
May 2, 2009. 9:26 PMSpeedmite says:
I read more and more of the comments, and I am shocked at gullible some people are. I am pretty sure this isnt the best instructions, no offense, and it might not be as good as MrCrowly's when you make it. Compare it to other thing in books and other sites to find the one to build that is right for you.
There are pneumatic and combustion cannons. Pneumatic cannons are safer and work up to 80 psi with my cannon. stronger PBC= more psi like 140. There are piston (like this one) and a much simpler valve one which there is no piston and one larger ball valve. I like the simple valve. and pneumatic.
Combustion are weaker at 15-30 psi, make a large boom and fire, and are more varied and simpler.
pneumatic is air pressure
Jul 6, 2008. 4:38 AMcoolpizzadude says:
Will paint eat any chemicals in the pvc.
Apr 30, 2009. 8:23 PMSpeedmite says:
PBC isn't styrafoam. Big difference.
1-40 of 293next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:MrCrowley(Spudgun forum I help moderate)
I love building things that shoot other things whether they be small plastic BBs or 135g steel ball bearings. If you need help with a spudgun feel free to ask on Instructables or on Spudfiles. My use...
more »
