Golf Balls in a Coke Bottle
139,895
325
74
Published
Introduction: Golf Balls in a Coke Bottle
About: I got an old sewing machine when I was just a kid, and I've been hooked on making stuff ever since. My name is Sam and I'm a community manager here at Instructables.
Put some golf balls inside a Coke bottle!
This is a conversation piece that I made just for fun. It would make a great gift for the Coca-Cola and/or golf lover in your life . . . or for anyone that just likes funky, interesting things.
Read on to see how I did this, and the techniques you can use to put whatever you want into a Coke bottle as well.
Here's a video I made of the process, if you're interested: https://youtu.be/0TQ-w0fW-VI
Step 1: How Do You Do It?
There's no great trickery here; this was done just as you likely suspected:
The bottle was cut and glued back together with golf balls inside.
However, that's easier said than done . . .
All details are covered in the following steps.
If you're interested I've also made an "impossible bottle" instructable, where the bottles were not cut or modified in any way. It's a fun puzzle that pretty much anyone can tackle. Check it out here: Deck of Cards in a Bottle.
Step 2: Cutting Glass Bottles
Cutting glass bottles has been a DIY rage for the last few years, and there are a number tutorials and videos all over the internet that cover various techniques and contraptions people use to cut bottles.
My recommendation? Don't overthink it!
There are simple procedures you can use to get a clean break, which I'm outlining in this Instructable. Jigs and cutting fixtures are great if you need to cut a lot of bottles, but for the occasional one-off bottle project you can get by well-enough without.
Here's what you need:
  • Bottle (I used a 12 oz/355 ml Coke bottle)
  • Simple glass cutter
  • Basic oil
  • Sturdy stack of stuff as tall as you want to make the cut
Put some oil on the cutting wheel of your cutter, and hold it firmly down on the stack of stuff so it sticks out about 1 cm or so. I made my score line at the very bottom of the label band on the bottle, right in the crease.
Hold the bottle firmly against the table and press it against the cutting wheel. Rotate the bottle in a circle pressing it both firmly downward on the table, as well as against the cutting wheel.
You should hear a little grinding/crunching noise as you rotate, which indicates you are scoring the bottle as needed.
Score a complete circle around the whole bottle. You don't need to go over a scored area more than once! As long as you heard the crunching sound as you passed over an area, that area is adequately scored.
Step 3: Stress the Glass
The glass will break along the scored line if you stress it by exposing it to alternating hot and cold.
For consistently clean breaks, in my experience you don't want the "hot" to be too hot (blowtorch? NO!), or the "cold" to be too cold (ice? eh, not needed).
I've had the best results using running hot and cold water to stress the glass along the score. Using running water applies the most uniform temperature changes to the entire score line at once. (As opposed, say, to using a lighter and piece of ice.)
Here's what I do:
  • Turn sink faucet onto a small stream of the hottest tap water I can get, and take a pitcher of cold water from the fridge.
  • Start with the hot water. Rotate the bottle under the stream for about a minute, focusing the stream on the scored line.
  • Then, with the bottle laying in the sink, I pour a stream of the cold water onto the scored line rotating the bottle as before.
  • I go back and forth like this till the bottle parts along the score.
In this case, the bottle came cleanly apart immediately once I returned it to the hot water for the 2nd time. Be sure to either hold both sides of the bottle, or keep it laying in the sink so you don't drop the half that falls away.
Step 4: Viola!
Dry the two halves the the bottle carefully, as the cut edges are obviously very sharp.
(I know the word is not "viola." Everyone knows the correct spelling is "Wallah!")
Step 5: Add Marks
To make putting the halves back together easier once there's glue involved, I added a couple of dots on either half with a marker. I did this after cutting the bottle, but a better way would be to do this prior to cutting.
The seam appears especially visible in this photo, but after adding the adhesive it becomes slightly less obvious.
Step 6: Remove the Date Code
Just for looks, I removed the date code with a rag and some Goof Off.
Keep this stuff handy, as we'll be using it to clean up a tiny bit of glue residue later.
Step 7: Balls
Get some golf balls, and wash them if needed.
Make silly comments while you do this, and giggle like Beavis and Butt-Head.
I'm using Pro V1's because my golfing buddies say they're the best. I don't buy the hype personally, yet I do get happy when I find them in the trees while looking for whatever ball I knocked in there in the first place . . .
Step 8: Glue
For the adhesive in this application, I recommend E6000.
Alternately you could try some 2-part epoxy, but E6000 cures plenty strong, dries clear and is less likely to yellow over time.
Step 9: Add Balls and Glue
I applied a tiny amount of glue with a toothpick around just the outer half of the cut edges on both the top and bottom halves of the bottle.
I pressed the halves together using the marker dots as a guide, and gently wiggled the halves together until they seated themselves back in their original position. I let the bottle sit undisturbed for about 15 minutes.
Because of the way I applied the glue there was no squeeze-out internally, but a little externally. I used a rag and some more Goof Off solvent to gently wipe away the tiny bit of adhesive that had squeezed out along the joint.
Step 10: Add the Cap
I popped the original bottle cap back in place for looks.
Step 11: That's It!
A 355 ml bottle holds four golf balls, and a 500 ml bottle holds five.
Got any ideas of what else would be cool to see inside a Coke bottle? If you put something inside a bottle like this, I would love to see a photo in the comments.
Thoughts, questions, feedback are always welcome. Thanks for taking a look!
  • Slow Cooker Challenge
  • Casting Contest
    Casting Contest
  • Flowers Challenge
    Flowers Challenge
74 Comments
Cool! But where the heck did you find a GLASS Coke bottle? I haven't seen a glass Coke bottle in years...
Costco's near me (Houston) sell various Mexican coke products, with real sugar and glass bottles. Many grocery stores seem to have them, but not stocked all the time.
In Montenegro we have galss bottles in reglural stores. Also we have pepsi,fanta,sprite. Is that cool? :D
Find a place that sells Mexican sugar Cokes. Ask around. Someone knows where they are sold.
Just about anywhere. Mexico bottled Coke is sold all over where i live. People like it because it is made with real sugar.
Almost any grocery store, walmart, etc. (*here in spith texas anyway...) Also, most Mexican restaurants sell the "Mexican bottled coke"
Hope this helps!
Put a coin in the bottle, shake for 5 minutes and the bottom will fall out.
does that work with beer bottles too?
Yes, it works with beer bottles. You have to give the (liquid-filled) bottle a good thwack with your palm making good contact with the bottle mouth- you're trying to push an air pocket down and into the bottle so you have to form a little vacuum for an instant. In my experience, the bottom doesn't blow out quite clean enough for gluing back on, but ymmv. You can also score a bottle with a glass cutter and then heat and cool, it will pop along the score line- many Ibles for that. Bottles make cool vases, cups, etc. and the necks make good guitar slides! Win-win
it should work with any bottle given the hit is done well. i've never done this personally however i've seen it done with beer bottles. I reference Myth Busters
I don't know about the coin thing, but there is a method of knocking out the bottom of an old-fashioned Coke bottle. I haven't done it in years, and I only did it a couple of times when I discovered it as a kid (because you lose the Coke).
With the palm of your right hand, whack the top of the cap while holding the bottle around the neck with your left. I will make a cool Ka-tunk sound. Do this a few times and the bottom will neatly fall off.
I kid you not.
As I said, you lose the Coke in the process. This is a sad discovery for a kid.
you can fill the bottle with water after you drink it. the effect is due to a vacuum cavity that is formed at the bottom of the bottle between the liquid and the glass during the impact. the water which does not compress or decompress well moves to fill the void at a much greater velocity then which it was created and the force of this is what blows out the bottom of the bottle
i thought so but then i was thinking of mentos in diet coke when that word came to mind. but yes it is cavitation.
Put vinegar and baking soda in it-once you drink the delicious goodness inside-and then do the trick?
Ooh, I'm going to have to try that!
just an idea but couldn't you remove the coke label and then replace it over the seam so that you can't see it?
How visible is the glue line?
