Golf Cart
55,278
32
29
Published
Introduction: Golf Cart
About: I am 19 and have been homeschooled my entire life. I spend most of my time making and designing things with parts I have lying around my house and garage. I live on a 10 acre ranch which gives lots of room...
How to make an old Golf Cart work again.
Step 1: Get Rid of Old Batteries
Ususally golf carts have 6 - 6 Volt batteries in them, If they are still good you can keep them, but if there not you will have to get rid of them.
Step 2: (If Old Ones Are Bad) Find Some New Batteries
The batteries in my golf cart were completely dead. I looked around online and at local stores for the cheapest new batteries I could find. I was going to replace all 6 of the golf cart batteries but, I decided to use 2 - 12 volt deep cycle rv batteries instead (much cheaper, ~$150 for 2 - 12 volts instead of ~$450 for 6 - 6 volts) The 6 - 6 Volts would give it 36v 220ah and the 2 - 12 volts would give it 24v 120ah. using 12 volts will give you half of the runtime and about 2/3 the speed of the 6's but its much cheaper.
Step 3: Rust
The motor in my cart was pretty much fine, only a little rust. I used WD40 on most of the moving parts. I still have to get some good grease for it though.
Step 4: Speed Control
The speed control in my cart is really really old, it only has 3 speeds and if your going slow all the extra power is wasted in heat. I could get a new one for around $200-$400 which would make it much more efficient and much smoother.
Step 5: Stuff I Plan on Adding Later
Battery Voltage/Capacity meter
Speedometer
Plastic/Plexiglass Side to keep rain and wind out
  • Make it Move Contest
  • Casting Contest
    Casting Contest
  • Oil Contest
    Oil Contest
29 Comments
your instructable is very good !
But I have a question,can you explain me the idea of amper hour?
Just yank all the battery powered stuff out & install a shaft drive motorcycle engine in it, This will give you speed, a transission (no reverse tho, unless you get the 6 cylinder Gold Wing) more reliability, and the lack of having to plug it in each night.
I've been told the rear end is modified from a Ford Pinto, but have no proof of that. But it should handle about any small engine if it is.
If you need help with this project please feel free to contact me.
Yeah, the motor uses about 800 amps peak and 140 on flat ground..
haha, wow, never used big motors like that before.
yeah, lol, it wieghs in around ~100 pounds.... :D
8| thats huge. you should build a cap-cart. basically, a bunch of MIT students modified a go-cart to be electric, and then they added ultracapacitors for a boost function. also has regenerative braking
Also it has a Shunt Wound 4 Wire motor in it, so youd need a special speed control.
I'm familiar with this one, it's the three-wheel sports model if I remember correctly lol. I'm glad that this was salvaged rather than scrapped, long live ye olde engineering! 8-)
Where could you get things like this for cheap?
I'm not sure, but try a golfcart store for used batterys and motors, and possibly controllers.
"...it can pull a huge amount of weight." What occurs to me there is that if it were geared differently it would have a lot more speed - I congratulate you for your attitude about re-using things. If I had this I would build a scaled-down 1929 Model A pickup (just for one real classy example), and try to rig up some wind-turbine generators of some sort to make it independent of the evil energy production-consumption complex. I have looked for used golf carts, and either somebody wants an arm and a leg or the thing is destroyed, and even then they want a lot.
You could gear it differently, it would be quite hard though. Mostly you would just buy a new motor with a higher rpm per volt. The fastest motor that will fit on this one would be about 35MPH.
Why not 3 12v and possibly rebuilds/re-mfg from battery shops (look in Yellow Pages) or good used ones from truck or RV take outs when they upgrade or service them. We had 3 12v from our trucks we were updating so were less than $50! Much less than paying for disposal!
I found another old golf cart. This one had a bad drive train and all the tires were flat, but the batteries (6 - 6 V/220 AH Deep cycle) were pretty new. According to the shunt I put in and the program I wrote for my laptop they have about 120AH left in them. I generally get about 25 miles a charge on somewhat flat ground.
you no you can replace the brushes in the motor for only like 40 bucks and the thing will run good again
It doesn't quite need new ones yet, still runs well on the ones in it :)
Thank you for your battery and price information, that was actually quite helpful for my current project, althought this wasn't really instruction for anything, that's my only suggesstion is maybe show how you put these parts in at least, just some constructive criticism, But your price guide was quite helpful, thank you.
That's pretty sweet, Glad it's workin out for ya. I'd be cramming every battery I could find into that thing, just to see how fast I could get it to go. Leevonk: does that speed control do reverse as well? 'cause I may actually try to use that on large-scale RC truck I've been working on.
