Step 2: (If old ones are bad) find some new batteries
The batteries in my golf cart were completely dead. I looked around online and at local stores for the cheapest new batteries I could find. I was go...
The motor in my cart was pretty much fine, only a little rust. I used WD40 on most of the moving parts. I still have to get some good grease for it ...
The speed control in my cart is really really old, it only has 3 speeds and if your going slow all the extra power is wasted in heat. I could get a n...
Just yank all the battery powered stuff out & install a shaft drive motorcycle engine in it, This will give you speed, a transission (no reverse tho, unless you get the 6 cylinder Gold Wing) more reliability, and the lack of having to plug it in each night. I've been told the rear end is modified from a Ford Pinto, but have no proof of that. But it should handle about any small engine if it is.
I'm familiar with this one, it's the three-wheel sports model if I remember correctly lol. I'm glad that this was salvaged rather than scrapped, long live ye olde engineering! 8-)
"...it can pull a huge amount of weight." What occurs to me there is that if it were geared differently it would have a lot more speed - I congratulate you for your attitude about re-using things. If I had this I would build a scaled-down 1929 Model A pickup (just for one real classy example), and try to rig up some wind-turbine generators of some sort to make it independent of the evil energy production-consumption complex. I have looked for used golf carts, and either somebody wants an arm and a leg or the thing is destroyed, and even then they want a lot.
You could gear it differently, it would be quite hard though. Mostly you would just buy a new motor with a higher rpm per volt. The fastest motor that will fit on this one would be about 35MPH.
Why not 3 12v and possibly rebuilds/re-mfg from battery shops (look in Yellow Pages) or good used ones from truck or RV take outs when they upgrade or service them. We had 3 12v from our trucks we were updating so were less than $50! Much less than paying for disposal!
I found another old golf cart. This one had a bad drive train and all the tires were flat, but the batteries (6 - 6 V/220 AH Deep cycle) were pretty new. According to the shunt I put in and the program I wrote for my laptop they have about 120AH left in them. I generally get about 25 miles a charge on somewhat flat ground.
Thank you for your battery and price information, that was actually quite helpful for my current project, althought this wasn't really instruction for anything, that's my only suggesstion is maybe show how you put these parts in at least, just some constructive criticism, But your price guide was quite helpful, thank you.
That's pretty sweet, Glad it's workin out for ya. I'd be cramming every battery I could find into that thing, just to see how fast I could get it to go. Leevonk: does that speed control do reverse as well? 'cause I may actually try to use that on large-scale RC truck I've been working on.
lol, yeah i thought about that.. but i dont have enough batteries that can put out enough power.. one thing about the shunt wound motors that this thing uses is that under no load they will just keep going faster and faster until it self destructs.
I used it for my submersible robot, worked great. Can handle up to 40 amps (not sure what your motor takes). See here for how to wire the microcomputer up to the motor controller and motors:
8| thats huge. you should build a cap-cart. basically, a bunch of MIT students modified a go-cart to be electric, and then they added ultracapacitors for a boost function. also has regenerative braking
I would recommend you use an actual oil or grease for lubricating. WD40 is pretty bad for an actual lubricant. You can use it to loosen rusted parts and get things moving, but then I would put some grease in there. How does this run at 24v?
its a little slower at 24 but it still goes about 6-8 mph, which is good enough for me, i use it to move stuff around, it can pull a huge amount of wieght.
austin: i got mine from a farm across the street from my house, it had been unused for something like 15 years. 0.755: yeah i'll change that, it was pretty rusted.. 15 years outside... :P
Bio:I am 19 and have been homeschooled my entire life. I spend most of my time making and designing things with parts I have lying around my house and garage.
I live on a 10 acre ranch which gives lots ...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
http://www.ifirobotics.com/victor-884-speed-controller-robots.shtml
http://www.instructables.com/id/E7THM8MY2UEP286QU3/
