3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pneumatic Golfball Cannon- Shoots 450+ yards!
Step 2What You Need
What You Need
Here's a list of what materials and tools I used:
Tools:
Power Drill
Dremel (Notr Required)
180 (fine) sandpaper
PVC Primer
PVC Glue
Angle Grinder (Not Required)
Lathe (Not required)
Materials:
2000mm/78" of 50mm PN12 PVC/2" NSF-PW Sch 40 PVC
1500mm/60" of 40mm PN12 PVC/1.5" SDR 21 PVC
2 x 50mm/2" pressure rated PVC end caps
1 x 50mm/2" pressure rated PVC 90 degree elbow
2 x 50mm/2" pressure rated PVC 45 degree elbow
4 x 50mm/2" pressure rated PVC tee fitting
2 x 50mm/2" pressure rated PVC female threaded socket adapter
1 x 50mm/2" pressure rated PVC male threaded bushing x 25mm/1" female thread
1 x 25mm/20mm male x male threaded brass fitting (1" x 3/4")
1 x 20mm female threaded galvanized 3-way fitting (3/4")
1 x 20mm male threaded brass adapter (3/4")
1 x 20mm female threaded galvanized 90 degree eblow (3/4")
1 x 20mm male threaded galvanized nipple (3/4")
1 x 20mmx25mm female x male threaded bushing (3/4" x 1")
1 x 15mm galvanized male threaded nipple (1/2")
1 x 15mm galvanized female threaded tee (1/2")
2 x 15mm male x 8mm female threaded brass adapter (1/2" x 1/4")
1 x 8mm 0-300psi pressure gauge (1/4")
1 x 15mm male x female threaded galvanized ball valve
1 x 8mm male threaded brass quick-connect (1/4")
1 x 8mm brass nipple (1/4")
1 x 8mm blow gun (1/4")
1 x 25mm irrigation sprinkler valve (1")
2 x 50mm pressure rated PVC male threaded spigot fitting (2")
1 x 50mm pressure rated PVC coupler (2")
1 x 40mm pressure rated PVC coupler (1.5")
1 x pocket nerf
1 x coaxial fishing line mount
19 comments
Jul 28, 2010. 1:16 PMPizzapie500 says:
WOAH! Maybe you should make a list for Americans and a list for other people (aka metric and not metric).
Aug 19, 2010. 12:08 AMking.of.arms says:
Yo crowley, Is there a equivalent of the 40mm PN12 PVC in metal pipe (steel or SS Preferred). I am in NZ also.
Sep 15, 2010. 8:31 PMking.of.arms says:
Hey again,
I have found out that the closest I could get in metal piping is 5shedule, ID = 44.98mm and 10shedule=42.76mm
For reference, do you have any idea the ID of the 1.5" SDR 21 PVC you used on this cannon? Then I will be able to determine which will be the better fit.
Thanks
Oct 15, 2010. 6:54 AMafridave says:
gooday ive heard of someone shooting batteries out of something like this,the large ones that go in radios, maybe this can give you more scope for using diffrent size tubes
Jul 29, 2010. 11:13 AMPizzapie500 says:
Oh. I meant that it looks sort of confusing with both measurements on one list.
May 31, 2009. 8:19 PMCtherJ says:
aout how much would the stuff cost in america?
Aug 30, 2009. 11:32 AMclemsonguy1125 says:
I built a version for 25
Aug 29, 2010. 4:19 PMpufferfish9108 says:
ur pic is my backround. i no the guy who photoshopped it
Aug 29, 2010. 5:32 PMclemsonguy1125 says:
Ok my bad, i just got i off google images, oh yeah by the was heres a video of my new piston valve http://www.youtube.com/watch?v=U4hxpIuE680
Aug 31, 2010. 4:48 PMpufferfish9108 says:
how u make it semi auto (i dont have a fast enough compressor. although i might make a co2 inflator.)
Sep 1, 2010. 1:13 PMclemsonguy1125 says:
I used a 4 gallon compresser and put a spring behing the piston, I piloted by a hose spray gun. I can get 10 shots before 125PSI drops to 90 psi, and since I have a 25 shot mag, Its not a big deal. I can peirce a can at 30 so its all cool. Oh yeah all this is when its regged down to 50 PSI.
Sep 1, 2010. 3:31 PMpufferfish9108 says:
how i make da mag
Sep 1, 2010. 5:08 PMpufferfish9108 says:
lol
Sep 1, 2010. 7:59 AMpufferfish9108 says:
thanks
Aug 29, 2010. 9:47 PMpufferfish9108 says:
cool srry cant sho u minehave no cam
Aug 29, 2010. 4:18 PMpufferfish9108 says:
did u do those conversions from memory or look em up
smart
Mar 22, 2010. 9:05 AMnathan549 says:
also does the air gun have to be directly on the sprinkler valve or can u have a tube running from it into the air gun to have the trigger in a different position?
Nov 30, 2008. 12:15 PMchrissexton20 says:
what is a 1 coaxial fishing line mount
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:MrCrowley(Spudgun forum I help moderate)
I love building things that shoot other things whether they be small plastic BBs or 135g steel ball bearings. If you need help with a spudgun feel free to ask on Instructables or on Spudfiles. My use...
more »
