3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pneumatic Golfball Cannon- Shoots 450+ yards!
Step 9Construction of the Piston Housing
  • last photo ←
Once your piston is done you need to make the piston housing.
Get your spare 50mm PVC tee and cut a piece of 50mm PVC pipe 7cm long. Solvent weld it to the socket end of the 50mm female threaded socket adapter and then solvent weld the adapter and pipe to one of the horizontal ports on the tee. If required sand out a small 'lip' inside the adapter to allow the piston to fit through.
Get two 50mm x 40mm PVC bushings and cut 1cm off the end of one of them. Cut a piece of 40mm PVC pipe 15cm long and solvent weld one of the bushings to the end and the other bushing just above the other. Then solvent weld the female socket adapter onto the bushing on the end of the pipe. One bushing should now be inside the adapter, and the other just above it.
Make sure the end of the pipe without the adapter on, is perfectly level. The piston is going to seal against this. It is absolutely necessary it is flat. Solvent weld the bushing that isn't inside the adapter to the opposite end of the tee that the first female adapter is welded too.
See the pictures for help.
The 15cm of 40mm pipe should now be half way inside the tee
10 comments
Mar 28, 2010. 8:20 PMhollowpoint says:
hello, i am having trouble understanding your instructions with the second section, (the 50mm x 40mm bushing section) as to how to put that bit together.
could you perhaps elaborate further on:
1) when cutting the bushing, which end are you cutting? The 50mm or the 40mm end?
2) Is the modified bushing the one that goes on top of the other or is it the other way around?
Also could you also provide a picture of the bushings together before the female adapter is attached?
-Thank you
Mar 29, 2010. 4:40 PMhollowpoint says:
sweet, thanks. its a bit more clear to me now. i noticed by the comments that it was old and i wasn't even expecting a reply so thats good enough for me. one more thing, it being 2 years ago that you built it, have you perhaps made a newer versions or any improvements with the piston valve that you could share with me...?
Mar 29, 2010. 6:58 PMhollowpoint says:
cool, thanks for the info again, i already have my own cannon planed out but to my surprise there is little to no info as to how to build a PVC piston valve using a Tee split (probable due to spudtech.com's "supah-valve" and those who have the know how tend to keep the info to themselves so they can charge massive amounts of money for theirs) <- might not be true but that's what im saying cause im mad about not being able to drop $200+ on a piston valves that are pre-made
recently i was surfing the web for PVC fittings and i stumbled upon these:
pvcfittings.com/graphics/7ways.jpg
my first thought when i saw these was "revolver!".
you could have 6-7 projectiles ready to go with some kind of O-Rings on the end of each port to seal and you got a spudgun in revolver/grenade launcher style.
May 17, 2010. 3:34 PMhollowpoint says:
back again! i made an amazing discovery about golf balls and barrel sizes... not sure if you already know this or not but i thought i might share, this afternoon i found my dog chewing on something odd, turns out it was a golf ball. i quickly took it away from him and found that he had chewed off the outer shell (the white part with all the dimples in it) of the golf ball leaving only the inner core. why is this important...? well, just on a guess i went over to my old combustion and tried to put the golf ball down the barrel and sure enough it fit perfectly down the 1.5in pipe.
so my discovery is that the inner core of a golf ball will fit perfectly inside of a 1.5in PVC pipe (sch40). this could be very helpful for any one who cant get their hands on some SDR 21 pipe or 40mm pipe.
Nov 3, 2009. 7:59 PMGrant1231 says:
 Okay so I get the concept on how it works but when the piston is sealing off the barrel how does the air get through to the rest of the tank? Or did you have to make sure that the piston was short enough inside the T so the air could get through or since the piston isn't completely air tight it just seeps around the back of the piston and into the rest of the gun?
Thanks
Oct 24, 2009. 12:12 PMFuingurth says:
So air pushes the piston right?
and then you cut off the air pressure by closing the valve, and the piston moves back to where it was before? How does that happen?
Oct 26, 2009. 1:20 PMFuingurth says:
like why wouldnt it jsut stay where it was?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:MrCrowley(Spudgun forum I help moderate)
I love building things that shoot other things whether they be small plastic BBs or 135g steel ball bearings. If you need help with a spudgun feel free to ask on Instructables or on Spudfiles. My use...
more »
