3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Good Digital antenna cheap!
Step 5Add a support to the furring strip
I wanted the furring strip to rest so the face of the aluminum strips, not their edge, would receive the signal. Twin lead is stiff and stubborn stuff. I drilled into the back of the furring strip and added a dowel rod to prop the furring strip up.
Connect the 300 to 75 ohm transformer to the input on your converter box. Connect the converter box to the TV. Run a scan so the converter finds available stations. Experiment with the placement of the antenna for your best reception and enjoy. Also try placing your antenna so it is vertical rather than horizontal.
When I was finished, I found this cheap antenna performs better than the commercial antenna in the first panel of this Instructable. It is not as dependent on directional alignment and once properly aligned, no channels pixelate or fail with "No Signal." It did not lose a picture when someone walked across the signal path.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
475
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
