3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Good Digital antenna cheap!
Step 7What is a parabola and how do I make one?
The definition of a parabolic curve is "a line equidistant between a point and a straight line." Go to a large table top and make a large sheet of paper from small pieces of paper. Newsprint works if you are using a felt tip marker. Make it a color like red or green so it stands out from the printing on the newspaper. Draw a straight line across the bottom. At its center make a line perpendicular to the straight base line. At about 14 inches (35.5 cm) mark the focal point. The distance from the base line to the focal point is completely your choice, but it affects the size of the reflector you make. Mark a point midway between the base line and the focal point. This is the first point you have plotted on your parabolic curve.
The "B" lines are always perpendicular to the base line. The "A" lines change their angle in order to connect with the "B" lines. Use two yardsticks and a square. Plot points where the yardsticks cross over one another while the measurement shown on each yardstick is the same. The more points you plot, the more accurate your parabolic curve will be. If you are careful, you can plot only the left half of the curve and then flip it over to copy it onto the right half of the paper.
The end result is that any signal (TV, radio, sound, light) coming to the parabolic curve in parallel rays will be gathered in strength at the focal point and amplified because they are concentrated.
2 comments
Feb 6, 2011. 8:18 AM-=Dr.Who=- says:
Try perforated aluminum or perforated stainless steel. Either one will work great and no worries about structural strength. Even heavy mesh metal screen (like a good strainer) can be used with just a little bit of aluminum or steel rod for support.
Apr 13, 2010. 5:51 PMadambh says:
An old satellite dish should work. There's one on my roof from when I moved in that I don't use. If I pointed it in the direction of the towers and mounted this aerial where the LNB goes, it may be ideal.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
475
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
