Gorgeous Photo Backlight Pendent
Published
Introduction: Gorgeous Photo Backlight Pendent
About: Thank you instructables!!
I have built this to keep a memory of someone and even in dark also and beautiful craft done on its surface .it is very simple to make and very cheap also. so friends please vote this view this and also help it to become a winner of necklace challenge.
Step 1: Making Box
Firstly measure the photo size and then keeping some margin on all four sides draw the rectangle on cardboard and then make the box net according to your needs and battery size i have kept 6 CM BY 4.5 CM BY 2 CM
Step 2: Making Electrical Fittings and Fitting Photograph
Make and join the circuit as shown in the picture and leave wires for switch outside the box and then mark the photo size on the rectangular cardboard and draw one more margin about 2 MM inside the outer rectangle as shown in the last photograph
Step 3: Joining the Box
As you already know according to that join all the box into a cuboid by cellotape or glue and newspaper i have used tape
Step 4: Showing Craft
Now on all sides firstly apply glue and then join sticks one by one and let them dry you can use matchsticks also for this keep sure that the switch wires are still outside
Step 5: Adding Switch
With instant glue join the wires to switch and solder them and join join the switch strongly outside the box and test the light also let it dry properly
Step 6: Box Checking
SEE ALL SIDES OF THE BOX AND CHECK IF ANYTHING IS NOT PROPERLYJOINED MAKE IT PROPER AND GO TO NEXT STEP
Step 7: Checking Light
CHECK THE LIGHT IN DARK ALSO IF IT IS WORKING OR NOT
Step 8: Joining Thread
Take a spool of wool and go to next step
Step 9: IMPORTANT PROCESS OF MAKING STRONG AND BROADER THREAD
Take an electric motor and join stick vertically to it with instant glue and then take a long piece of thread and fold it into half and join the both ends to motor sticks respectively and rotate the motor when it gets totally then again fold it into half and THEN YOU NEED NOT TO REVOLVE IT WOULD AUTOMATICALLY SWIRL AROUND AND BECOME A BROAD THREAD
Step 10: JOINING THREAD
Take two nails and join them to box on both sides and then fix the thread ends to it
Step 11: WOW !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
NOW SEE HOW GORGEOUS IT IS AND PLEASE COMMENT , FAVORITE , VIEW , VOTE IT
THANKS!!!
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    4 Discussions
