3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Gorilla Pod
Gorilla Pod
Yet another camera tripod project with Loc-Line modular hose. This instructable owes its existence to the Gorilla Pod instructable by benthekahn. Before reading this one, read that one.
This extends and, hopefully, improves and simplifies the instructable mentioned above. This version of the tripod folds flat and allows for a variety of upper camera mounts. This increases the number of angles at which a (lightweight) camera can be held. It retains all of the advantages of the Loc-Line model -- flexibility, durability, and general coolness.
Step 1Blah Blah Blah
This step is here because the first step seems to appear below the Introduction. I don't understand why and I don't think it is a good idea.
19 comments
Aug 5, 2011. 8:58 PMguyzo35 says:
This is fantastic!!!  Few projects get me inspired enough to emulate them, and your presentation truly got to me. I work in a machine shop so I made my version out of spare parts (aka COMPLETELY FREE).
I used a plastic base 2"x2"x0.5" square, and did exactly what you said with the tapped holes.
One improvement on the connection between the screw and Locline piece: I used a 1/2" bolt (http://www.mcmaster.com/#cad-2d/91274a156/=dhu97a), McMasterCarr Part # 91274a156.
The head of the bolt is too large for the smaller hole of a Locline hose part, so I machined the hole to be a few thousands smaller than the diameter of the bolt head, put glue in the newly drilled hole, and press-fitted the bolt into the Locline hose.
I also added a 1/4-20 nut and lock washer, so that when the camera is screwed down all the way it stays in place and doesn't swivel.
Thanks for the awesome idea!
Aug 8, 2011. 7:10 AMguyzo35 says:
Hahaha, that would a Bridgeport Milling Machine:
http://cgi.ebay.com/Milling-mill-machine-9x49-3HP-220V-electronic-variable-/110722348048?pt=BI_Mills&hash=item19c790f410#ht_1717wt_700
Extraordinarily expensive for the common layman, but infinitely useful if you have access to one.
There are machine shops in various places that allow access and memberships to use their machinery if you're interested:
http://techshop.ws/ (as an example)
Apr 16, 2011. 1:51 AMrarora says:
just checked out the loc line, its expensive.. buying a gorillapod would be cheaper(and better)
Dec 20, 2010. 9:27 AMmarinstruct says:
It might be cool to fasten some rare earth magnets to the ends of the legs, so it would "stick" to ferrous surfaces. ...well, maybe not the roof of a moving car.
Dec 20, 2010. 2:42 AMernestmac13 says:
Have you played with a Gorilla pad, they are pretty cool? I ask because, they have solid joints with a ring of rubber running around them, which along with their rubber feet help to prevent scratching what you wrap it around or set it on. I especially like the multiple heads, one standard 1/4", one with a suction cup for attaching a cell phone, and two with double sided sticky goo. The last one has goo similar to those hooks you put on the wall, that you pull on the tape to remove goo and all. The suction cup has mixed results, with my vary heavy Motorola droid phone. I need to contact Gorilla, for a better solution. Other than that, I'm happy with both my mini-Gorilla Pod, and the full sized one for full sized cameras and video cameras. I'm sure making the tripod was a great learning experience, which is what instructables is all about, but in that same line, I think determining which would actually function better for the dollars spent, is also important.
Dec 19, 2010. 7:55 AMFightCube Technologies says:
Very nice project, I'm fascinated with uses for loc-line as well. Where exactly did you buy your loc-line?
Dec 19, 2010. 9:27 PMPilgrimm says:
Try this link:
http://www1.mscdirect.com/CGI/GSDRVSM?PACACHE=000000166450128
Good luck.
Dec 19, 2010. 2:41 PMsjoobbani says:
I like this idea.
I noticed loc-line many years ago,
and I was going to use it in a sort of way to make a tripod
but not exaclty a tripod
Dec 19, 2010. 8:56 AMalaskanbychoice says:
You might also try adding stiff cable to the inside of the line-loc to give it strength and security.
Dec 19, 2010. 7:54 AMFightCube Technologies says:
I just thought of a nice modification, or addition. If you added a little alligator clip (or crocodile if you prefer) to the wood piece, it could be used to keep your hand strap out of the way. It could also be used to hold small things like maybe a flower stem or ring so that you could position them just the right way to take a shot. The clip would ideally be on some loc-line for holding stuff, but not necessarily loc-line if you just want to hold the strap.
Dec 19, 2010. 7:28 AMturbotonic27 says:
awesome project
Dec 16, 2010. 4:42 PMbrbenn says:
Nice Innstructable!
Dec 15, 2010. 3:07 PMsteveastrouk says:
Isn't it cheaper and better to actually buy the gorilla-pod, because those rubberised bits are much better than loc-line ?
Dec 14, 2010. 10:57 PMJamesRPatrick says:
This feels incomplete.
Dec 15, 2010. 8:40 AMSlightly Askew says:
I think a final step displaying assembly instructions ("attach Loc-Line", as you say in this comment) at the end is what is missing. Shouldn't have to jump out to another ible to get that final crucial step. Just my .16 bits.
Dec 15, 2010. 8:59 AMJamesRPatrick says:
Also, the final product should be featured in the final step.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:matth3w
