Got a Stereo and No Harness?
114,798
23
12
Posted
Introduction: Got a Stereo and No Harness?
I picked up a Pioneer AVIC-F700BT, it was a deal so it was missing the preamp wire harness. There are times when you find a cheap car stereo missing a few accessories (thats as much as I'll say about that). When you do, you'll need a wire harness. I thought it would be helpful for certain people to write a how-to on making your own.
Step 1: Starting Out
This is the port that we need a harness for. It has 12 pins and handles the preamp outputs of the stereo for connection to an external amplifier. The harness for it would come in the box if this unit was bought new.
The first thing you need to do is find the pin-out diagram to tell which pin handles what function. These things are available all over google for whatever port you might find.
What else do you need: Soldering iron, glue gun, continuity tester, shrink wire, port connector, female a/v jacks
Step 2: Understanding the Pin-out
I found the diagram for this stereo on some forum. Since I'm making my own harness I have a choice which features I can live without so i got less soldering to do.
Here I'm going to use the six audio channels, the amplifier remote wire, and mute wire
Right now I'm ignoring the rear view camera and video hookups.
Step 3: The Connector
In the first image is the original connector, it had like 100 pins i think. You can get these from all kinds of catalogs like Digi-key, Allied or Radio Shack. I cut it down to 22 pins (not 24), it fit better so in the last pic you can see the two pins exposed. These handled the rear view camera so I didnt need those. But as you can see this fits perfectly and now we're ready to solder some wires.iption of the Step
Step 4: Extend the Leads
When soldering make sure you put some solder on both the wire and the connector, they'll attach much easier. After soldering use a piece of heat shrink wire to insulate the connection. This is very important because the pins are so close together and you don't want anything to touch. So insulate EVERY connection.
Heat shrink wire is available at Radio Shack and will be somethign you wont do without after the first time you use it. It is a larger diameter tube that slips on over your soldered connection, once in position, hold the soldering iron to it to heat it up and the tube will shrink tightly over the connection to insulate it.
Solder a wire to every pin identified by the pinout diagram. This can get pretty tedious. The end result will be very flimsy and will need to be secured later before you plug it into the back of the stereo.
Step 5: A/V Hookup
You now need to find some female A/V jacks. These are pretty hard to find in stores so I found an old VCR. Bust it open and take them out. The outside metal of the jack is the negative while the inside is positive so solder the leads accordingly. So the ouside will be connected to the audio channel ground (with this unit the ground is shared between the left and right channel of each front, back and subwoofer) Once soldered on, use a continuity checker to make sure that there is a connection.
Step 6: Secure the Connection
While trying to rip those a/v jacks out of the vcr, i broke two of them so i had to find these (in the picture) but it's the same thing. When you finish soldering all of this together use a glue gun to melt plastic over the connections on the pins to make sure you dont rip them off while installing.
Make one last check with the continuity tester. Since its impossible to test the positive connections when then unit is off, you can still check the grounds. Finally, to avoid being disapointed after you rip the dashboard off your car to install this, with the harness plugged in make sure there is a continuity between all the negative sides of the a/v jacks to the unit's ground wire.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    I have a ASWC-1 that needs a wire harness I know which pins I need and also the color. How do I figure out what size female connectors I need?
    10 Comments
    How to make harness for dual flip out dvd deck
    Need help making a factory harness for my JVC kd-r870bt stereo reciever was given to me with no harness thanks
    I was given a JVC kdr-870bt stereo with no factory deck wire harness I'm trying to make one so not having to buy one need help to make one thanks
    Hello I have a Panasonic cq 100 800u I believe I need help finding a graph like you have to know the meaning of each color wiring thank you
    I just bought one today from a friend that has no harness.
    Just because it lacks one doesn't mean it's stolen. Most of us car guys can figure out the wiring without a harness anyway so your statement is rather ignorant.
    I'm looking for a way to find configuration pins for the power plug, any thoughts?
     Won't hot glue melt when the dashboard gets hot?
    Maybe, its mostly for durability during the install, after its in the dash its not like the wires will flex and move around much. So even if the hot glue gets a little mushy in the heat, i dont think it would be a big deal.
    i wish i read this befor i spent almost an entire day at the junkyard looking for one that would fit my stereo
    good idea i buy head units alot cuz i have anger issues, and i never thought of this, save me 25 to 50 everytime i need a new wire harness, i would jis order them now i can jis make um thanks-jman
