Introduction: "Got Milk? Drawer Cabinet" or "esta Cajonera Es La Leche!"
I need to improve my workshop with little drawers to stack some tools and/or various materials. But I'm not convinced on spend 12 or more €uros in a plastic ones as I found on the "all at €uro" store for only 3 drawer...
And after some days thinking on it, one morning while putting my coffee’s milk in a mug, I realize about the milk carton are a good material to do this, and I decided to build my drawers with these dairy can's.
To build this, I used only recycled materials. I have the lucky about in my city (Barcelona) all the weeks there is one day where everybody can throw old furnitures on the street (not in a chaos! on the corner or near the door), to be recycled by the city council clean brigades... and all Barcelona’s students which pick'em up to furnish her flats, or all kind of people to re-use wood or furnitures... like myself...
Anyway, this summer I found some chipboard plates with blue colored veneer and two large thin hardboard.
With one of this blue chipboard plates, one of the hardboard ones, some milk cartons, blue wrapping paper, recycled from last Christmas presents, carpenter white glue, a power jigsaw, a drill (can be a multi-purpose like a Dremmel one), scissors, 15cm Threaded rod, some clamps, and a rule to take measures, I go to buil up this "Dairy Drawers".
Let's see how I build it (if you want, of course)
Hola Instructableseros!
Necesitaba mejorar mi taller añadiéndole una cajonera para guardar materiales o pequeñas herramientas para mis trabajitos. Pero no me convencían las cajoneras de plástico del "todo a cien", 12 €uros o más por tres cajones de plastico...
Así que tras unos días de darle vueltas, una mañana, al prepararme el café, me dí cuenta que el envase de la leche, el Tertrabrik, era un buen material para hacerlo, I claro, decidí crearme una cajonera que fuera "la leche".
Solo usé materiales reciclados. Tengo la suerte que en Barcelona, donde vivo, cada día de la semana, al anochecer, los habitantes de un distrito distinto de la ciudad pueden dejar en la calle muebles y otros onseres viejos para que las brigadas municipales los recojan para reciclarlos. Cosa que aprovechan todos los jovenes para amueblarse los pisos de estudiante o "los raros/listos" como yo mismo para reciclar maderas y muebles. Este verano tuve la suerte de encontrar unas planchas de aglomerado con la melamina de un color azul interesante y unas planchas de táblex bien grandes.
Con estas maderas, varios tertrabrik de leche, papel de envolver regalos, que sobró de navidades (kraft azul), cola de carpintero, la caladora, el taladro, tijeras, varilla roscada, unas mordazas y regla, empecé a construir la "Cajonera la Leche!".
Step 1: 1-Design and Collect Materials - Planeando Y Recogiendo Los Materiales.
For my requirements I need some little drawers and two bigger ones to keep in them some pencils and wood sticks.
I make a little hand-draw design which serves to think in the measures. The base measure are the ones of a milk's tetra-pack which are of 6 x 9cm. To decide the height of a drawer, I measure which is the deeper I can reach with bare fingers. If I do the single drawers deeper, I can't take what I put in there!
In my case, what my fingers could reach are 6cm depth.
With this in mind, I decide about my Dairy Drawers measures needed to be 38 X 20,1 X 9,5 cm (width, height, deep) to contain 2 single big drawers, and a matrix of 3x3 little drawers.
I plan to open the big drawers by swinging them and the little ones by pulling them.
To collect materials, is the easiest part of this ibles, and consist in take breakfast and once the milk cartons or "tetra-briks" (from oat, soy, rice or juice from orange, tomato, cow*... etc... ) are empty, cut them to unfold, and clean it up with warm water.
Mis necesidades son crear 2 cajones grandes, que me permitan guardar lápices o palitos y varios cajones más pequeños para guardar otros materiales.
Hice un pequeño diseño a mano alzada y así pude tomar las medidas, la medida de base, fue la de un tertra brik, 6cm lado X 9cm de fondo. Para saber la altura necesaria, me medí los dedos de la mano para averiguar hasta a que profundidad era sencillo recoger un tornillo, y en mi caso vi que eran seis centímetros. Si lo hubiera hecho más fondo, no podría coger nada!
Con esto en mente, decidí que las medidas de mis cajonera "La leche!" serían de 38 x 20,1 x 9,5 (ancho,alto, fondo) conteniendo 2 cajones grandes y una matríz de 3x3 cajones pequeños.
Los grandes se abrirán por balanceo y los pequeños tirando de ellos.
Conseguir los materiales es la parte más fácil de este ibles, y consiste, en la práctica en desayunar y una vez vacíos los cartones o tetra-briks de leche (de cebada, soja, arroz, o zumo de naranja, tomate, vaca*...etc...) cortarlos con unas tijeras para abrirlos y limpiarlos con agua tibia.
* Yes, cow juice :P
* Si, lo sé, zumo de vaca :P
Step 2: Cutting and Assembling - Cortando Y Ensamblando
Once the design was made, the measurements must be marked onto the wood with pencil and rule. The only important thing I must get in touch is about the chipboard plate is decorated on all sides, and I plan the cuttings on the way to use it for all sides of my drawers.
I got no circular saw nor band-saw and for cut this I need to use a jigsaw doing slow cutting work to prevent curved sides.
With hammer and chisel I do the joints on the hardboard. And with the drill equipped with a spade's bit I do the hole where the metallic nut to hold the Threaded rod goes. In that hole, I place the metallic nut fixed with hot glue.
To assemble the external structure, and to mount the internal structure without any problems, I joint the side without the metallic nut with the upper and down faces. I do little holes with a dremel drill where the screws goes, with this I prevent the veneer to crack.
Now, it's time to build up the hardboard internal structure which subject the little drawers, but without installing the plate where the Threaded rod goes. Having done that, and before mount the other chipboard external side, we need to mount the big drawers in the Threaded rod, but... Stop! Before it, we need to wrap this drawers (if we want it).*-----------------------------------------------------------------*
Una vez realizado el diseño, con lápiz y regla, marcaremos las medidas en las maderas. Lo único importante que tuve que tener en cuenta, es que el conglomerado que usé ya venía con los embellecedores en los cantos, con lo cual, realicé los cortes para aprovecharlos.
A falta de una sierra circular, de mesa o de cinta, yo usé la caladora yendo bien despacio para procurar hacer los cortes lo más rectos posibles.
Una vez cortadas las piezas grandes de táblex, procedí a realizar los encajes con serrucho y martillo y formón. Para el agujero para pasar la rosca de la varilla roscada con el taladro equipado con una broca de pala, este mismo agujero, se ha de repetir en el lado del armazón que va a sujetar el otro lado de la varilla.
Entonces, coloqué las roscas para sujetar la varilla en cada uno delos agujeros preparados para recibirlas y con cola de calor, las pegué para que no se soltasen.
Para realizar el ensamblaje, primero monté uno de los laterales con las piezas superior e inferior del armazón lo cual, me permitió montar la estructura interna sin problemas.
Para clavar los tornillos de sujeción del armazón, una vez presentadas las piezas, con la Dremel (podría haber usado el berbiquí) realicé un agujero con una broca fina y entonces pasé el tornillo. Con este agujero evité rajaduras que a veces salen al clavar tornillos directamente en la melamina.
Procedí entonces a montar la estructura de táblex que sujeta los cajones pequeños, sin montar la pieza dónde hemos colocado la rosca para el tornillo.
Una vez hecho esto y antes de colocar el otro lateral del armazón, hemos de colocar la varilla roscada y los dos cajones grandes que irán sujetos con la varilla roscada. Pero alto! Antes, los hemos de agujerear y forrar.
Step 3: Wrap - Forrado
Before to wrap the bigger drawers, I need to perforate them where they goes subject with the Threaded rod. To measure where I need to do this hole, I mark it before with the hardboard plate which have the metallic nut fixed. Once marked I do the hole with a wood drill, but you can use a cutter, scissors or a similar object...
After that I need to see where this drawer must be cut in diagonal to allow to be opened by swinging it. To see this, I place the drawer where must go and mark the back upper point which contact with the chipboard structure. From two or three millimeters down this point to the upper front part of this drawer, I do a diagonal cut to allow the aperture.
At this point I begin to wrap the drawer as if I'm wrapping a book. All kind of paper can be used, kraft, scrap, or anything or if you like the milk carton decoration, nothing. In my milk cartons, the bottom part is where the bar-codes goes for one side and the farm address for the other, and I don't like that. I use blue wrapping kraft paper which left over from enveloping last Christmas presents, sticked to the drawers with carpenter white glue extended with a brush.
Once this drawers was wrapped, I feel there is nothing to pull them to open, and for that I cut two tongue shaped pieces of milk carton. I wrap them and attach in the front part of these drawers.
Antes de forrar los cajones grandes, los agujereé por donde van sujetos a la varilla roscada. Para esto, coloqué la parte de la estructura interna donde fijé la rosca, y marqué donde va el agujero. Yo lo agujereé con una broca de madera pero se puede hacer con un cutter o similar.
Entonces presenté el cajón para ver el corte en diagonal que le tenía que dar y que permite abrir el cajón por balanceo. Marqué en la parte trasera del cajón donde contacta con la madera y desde unos milímetros menos de este punto y hasta la parte superior frontal del cajón, tracé una linea y corté el cartón por la misma.
Entonces, y como si de un libro se tratara, a pasé forrar el cajón. Se puede usar cualquier tipo de papel o si nos gustan los colores de los cartones usados, no hace falta forrar. En mi caso yo usé un papel de envoltorio que había comprado por navidades y que me sobró, además, al ser de color azul, queda a juego con las maderas de la estructura externa.
Para forrar los cajones, usé cola blanca extendida uniformemente con pincel.
Una vez forrados estos cajones grandes, me dí cuenta que no tenía por donde tirar de ellos, así que corté unas pestañas de otro cartón de leche, las forré y las pegué a estos cajones.
Step 4: Structure Final Mounting - Montaje Final De La Estructura
Once I do all that, I insert the threaded rod to the metallic nut fixed in the lateral plate of the inner structure being careful to do not pass the threaded rod until the end to allow fix it to the other nut by grabbing it with pliers.
I place the big drawers in the Threaded rod separated one to another by a washer.
And I put this structure in place and once this is done, put also the missing external chipboard side, and fix it with two screws.
With a pair of pliers i coil the threaded rod until it reach the other nut and lay in her final place.
Realizado todo esto, pasé la varilla roscada por el tornillo del lateral de la estructura interna, teniendo en cuenta de no pasar la varilla hasta el fondo de tal manera que quede un trozo suficiente cómo para poder sujetarla y pasarla por la otra rosca; coloqué los cajones grandes a sitio separándolos entre ellos con una arandela y ahora si, coloqué esta estructura a sitio, con la placa de táblex sujetada a la estructura ya instalada.
Aquí llegó el momento de colocar a sitio el lateral de la estructura externa faltante y lo sujeté debidamente con los tornillos preparados de antemano.
Con unos alicates fui dando vueltas a la varilla roscada hasta que esta contactó con la otra rosca y quedó sujeta a sitio y con ella los cajones grandes.
Step 5: Finishing - Acabados
At this point I begin to cut and wrap the little drawers.
The basic form of them are rectangular but in one of the superior sides I left a thonge to allow to pull them.
In this moment, I think to build some pullers made of wood, buttons or buy some at the hardware store, but in order to use the minimum quantity of materials I do these pullers with a thongue shaped piece of the same milk carton.
I wrap this drawers like the other ones, with carpenter glue extended with a brush.
For the pullers first I wrap the external side leaving some tabs to bend at the inner side and cover this inner side with half moon shaped piece of paper.
Pasé entonces a cortar y forrar los otros cajones, los pequeños.
La forma básica de los cajones es rectangular, pero en uno de los lados superiores, dejé una lengüeta para usarla cómo tirador.
En su momento sospesé la idea de hacer tiradores con madera, botones o comprar unos en la ferretería, pero al final, me decanté por usar el mínimo de materiales diferentes
Los forré igual que los otros, con cola blanca extendida con pincel para que el papel kraft cogiera uniformemente. Y Para los tiradores, recubrí primero la parte exterior dejando una serie de pestañas para doblarlas por el interior y la parte interior, cubierta por una lámina de papel con forma de media luna.
Step 6: Hangers - Colgadores
The last step was mount some hangers to the backward side of the chest drawer to allow it to hang if needed.
To do that, with the help of hammer and chisel, I cut a little V shaped slot . Cover it with a metallic flat bar fixed with screws and...
That's it!
Do you like it? I hope yes!
Bye!
P.S. How You can see this is a design which can be easily converted in a modular wall chest or with a simply re-wrap changed to give them a interesting new life...
P.S.S. Sorry for my bad english grammar... I'm taking online classes, but ... steady ones... :P
El último paso, fue montar unos colgadores a la parte posterior de la estructura.
Con el formón realicé unas muescas y encima de estas, coloqué unas pletinas metálicas sujetas con tornillos para poder colgar la cajonera en caso de necesitar-lo.
Y... Ya está!
P.D. Cómo podéis ver, es un diseño que fácilmente se puede convertir en modular, ampliar o con un simple re-forrado de los cajones darle un interesante cambio de aire. En definitiva, Esta cajonera, es la leche!
Furniture Contest
