3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Gouge for a Lathe the good and cheap way (Oland Tool)
  • last photo ←
Good gouges are expensive; but not this one! I was happy to discover this great DIY lathe tool. It's called an Oland tool http://www.aroundthewoods.com/oland.shtml it was invented in the 1970's by Knud Oland.
Common wisdom tell us you can't have it all; you must choose between three factors: you can have it inexpensive, high quality, and easy; but you may only choose two out of three.
But with the Oland tool you can have it all!
This tool is cheap to make, easy to use and functions well. Constructing this gouge involves regular shop tools and common, inexpensive materials.
The parts are:
-a big dowel (free from the scrap pile, you could even substitute this with a scrap of 2x4)
-a 16mm X 30cm steel rod (18"x3/4"): 300 yen
-a 6mm (1/4") lathe blade (from a metal lathe): 2000 yen but probably way cheaper in your country. This was too expensive for me so I used a hardened steel concrete nail instead.
-a 5mm .8 thread machine screw (or a 1/4x20 thread): there's probably one in your pocket right now.
-2 meters/6 feet of thickish 1~2mm 1/8~1/16 steel wire: very cheap
=Not much money.
The tools are:
-drillbit the same width as your steel rod (to drill wood).
-6mm or 1/4" drillbit (to drill steel)
-5mm .8 or 1/4x20 thread tap
-5mm .8 or 1/4x20 bottoming tap (Mothflavour2 suggested a workaround so you don't need a bottoming tap see step 4)
-drill bit appropriate for your tap size.
-a drill
-a grinder with a narrow wheel.
That's all folks!
See the thing in action on my foot-powered lathe:
Step 1Cut dowel to length and drill
Cut your dowel to about 2 feet long.
Drill a 3 inch hole down one end.
In my case, my steel rod was threaded for about 3 inches on each end. This meant that it screwed down very nicely into a 15mm wide hole!
If your steel rod is not threaded, you might want to drill through both the dowel and the rod and put in some set screws to pin everything together.
8 comments
Apr 3, 2010. 4:20 PMjomaro says:
Thanks for sharing this. I'm sure these will be great tools even if some of the tool collectors at Flickr's Tool Porn won't agree. And concrete nails are such a cheap source of hardened steel!
Those interested in a treadle wood lathe should check here.
Thanks!
Mar 15, 2010. 12:21 PMjoeyjo says:
I have heard and read that many turners make these from tool stock. I wanted to make some for my students because the oland tool is said to reduce catches.  I recently purchased some stock from Enco (#110024 - 3/8" M2 round tool bit) to make oland gouges, but I have not made them yet because I have never seen a good picture of an oland tool to match the grind.   Your photos are very clear.  Are the wings of the bevel really that steep?
Dec 19, 2009. 11:18 PMfrollard says:
I've never worked with a gouge as small as 5mm...does it offer a lot more awesome?
looks like a great tool!
Dec 20, 2009. 1:31 AMfrollard says:
Fantastic!  Treadle power is a perfect explanation of how this is extremely superb! :D
Dec 19, 2009. 4:15 PMrimar2000 says:
Interesting tool!
Dec 19, 2009. 3:44 PMmothflavour2 says:
I've discovered that if you don't have a bottoming tap, you can still make the threads all the way through by simply drilling the hole all the way through the other side and letting the tap thread through the whole piece.  That way, you end up with two tapped holes, both of which are completely threaded, yet you still have the option of only using one.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:snotty
Careers: documentary filmmaker, DOP, engineering student, practical environmentalist, idealist. Loves: bicycles and when weeds grow in the city. I'm from western Canada, Yukon, Japan and Montreal.
