3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Grape Juice!
This Instructable will show you how to make grape juice.
Grape Juice is a bit more simpler to make than wine. Making grape juice is also alot cheaper than buying it.
I would highly recommend you give it a try!
You may need to put your grape juice in the frige or freezer to stop it fermenting.
Step 1What you will need
Things you will need
A Colander for rinsing the grapes
A Large pan to cook 8 pounds of grapes (this will be used to mash and boil the grapes aswell)
A fine sieve to Strain the mashed grapes
Another large pan to collect the grape juice
11 comments
Oct 19, 2009. 1:43 PMlemonie says:
Ferment this stuff?
L
Oct 20, 2009. 6:30 AMPKM says:
A decent set of Instructions on the topic can be found on <a href="http://www.winesathome.co.uk/forum/showthread.php?t=1562">this home wine making forum</a>, aimed at beginners. Since my landlord gave up on his 4 gallons of plum wine to concentrate on his Pilsner brew I'm considering trying my hand with regular grape wine.<br />
Oct 20, 2009. 10:38 AMlemonie says:
I'll try to remember that for next time.
L
Oct 19, 2009. 11:28 PMlemonie says:
I know, but had you thought about it? If you keep it long enough it may start to ferment anyway.
L
Oct 20, 2009. 10:37 AMlemonie says:
Good idea.
L
Oct 19, 2009. 2:28 PMKozz says:
++lemonie
Good question.  And if one plans to ferment, I wonder what's the spec. gravity of unadulterated grape juice?  Or what type of sugar should be added, if necessary?
Oct 19, 2009. 2:45 PMlemonie says:
Good grape juice doesn't need sugar, and I believe it to be some kind of wine-crime to add any. However, if you're looking at SG w/ref to alcohol content I could advise (out of the Boots Book of Home Wine Making and Brewing 1970) Regular sucrose works OK.
L
Oct 19, 2009. 3:05 PMmikeasaurus says:
Any sugar added would only facilitate the fermentation process acting as food for the yeast and shouldn't add to the sweetness of the wine. If your grapes are garbage once fermented it will be alcoholic garbage.
I agree that it's a faux pas to add sugar to grapes to induce fermentation, which is why only certain varieties of grapes (and other fruit) are used to make wine.
Also, pretty sure you wouldn't cook the grapes or the juice for fermentation. However you will need to know the SG before beginning anything, and adjust pH .
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
40
Author:oscarthompson
I like to make instructables which are fun to build or make. I'm instrested in rockets, Bikes science and Rowing. send me a message if you have any questions.
