loading
Step 2: Basic Example for Arduino
Here's an example to graph an analog sensor, such as a potentiometer. The analog pin is A0 for these examples.
void setup() {
  Serial.begin(9600);
void loop() {
  // Analog Sensor Connected to analog pin 0
  int SensorVal = analogRead(A0);
  for(int i = 0; i < SensorVal; i++) {
    Serial.print("l");
  Serial.println();
  delay(50);
Try it, you know you want to!
 When you do try it, you'll notice that the graph is sideways, and the bottom of the Serial Monitor shows the most recent reading of the Sensor.
You'll also notice that the graph can get quite long, and may be wrapped around to the next line if the windows isn't wide enough. To fix this we can use a function called map();
this will take in a minimum and maximum value for your sensor, and then scale it to a desirable output.
Here's how the code would look like for this example. Note, 1023 is the maximum output value for the analogRead() function. also note, we are scaling the analog read function to a value from 0 to 100. You will need to place this line of code before the for loop in the earlier example.
SensorVal = map(SensorVal, 0, 1023, 0, 100);
Here is the complete code for a scaled graph of an Analog sensor on analog pin 0.
void setup() {
  Serial.begin(9600);
void loop() {
    Serial.print("l");
  Serial.println();
  delay(50);
About This Instructable
9,998views
30favorites
License:
Bio: I am a young engineer who likes to build things. My motto is Why buy, when you can Make! in 2010 I got an Arduino ... More »
More by Chowmix12:Graphing on an Arduino, the EASY WAY! Graphing values in Arduino, the EASY way! Never lose an RC BodyClip again!
Add instructable to:
