3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Gray-B-Gon wind-powered evapotron for graywater disposal
Step 31On playa: install the water filter
The five-gallon plastic bucket with holes will house the water filter. Set the bucket on the fabric scrap, which protects the plastic sheet. To tether the bucket against wind, pass twine through both halfway-up holes and anchor the ends to one corner staple and one side staple.
Examine the panty-hose for holes, and tie a knot above any holes in the legs or feet. Turn the panty-hose inside out. (You may find, as I do, that looking down at the inside of panty-hose is disturbing. It's surprising what a difference reversing it makes.)
Stretch the waist over the bucket rim, and tie it in place with twine. A good knot to use is the  lark's head noose ( http://www.instructables.com/id/Larks-head-noose-an-easy-useful-knot-that-tig/ ) It requires about 8 ft of twine. Be sure to "lock" it by adding a shoelace knot. If you need to adjust or replace the panty-hose, pull out the shoelace knot and slide the lark's head sideways to loosen it.
A sand filter is often used when processing graywater for reuse.  We just want to get rid of it, starting by removing the chunks.  A fine mesh filter does this well -- playa dust doesn't clog it, and it's much easier to transport.
2 comments
Apr 2, 2009. 7:26 PMstrad27 says:
Since the propeller apparatus is fixed in place, when the winds shift, what is the effect? Do you rotate the entire unit, or did you find that unnecessary? We're very interested in adding this type of wind-driven movement to our existing pond to speed the process up from last year. Also, in light of 2008 dust storms, did you find any problems with sediment build-up? Last year we had plexi walls which helped, but we would lose those if we followed your plan.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:Larry Breed
