Step 5At 88-90 degrees turn off the heat and stir in the Rennet solution for 15-20 seconds.
All Steps Viewing
If you are using another type of rennet, refer to the instructions they may have inside. Junket takes awhile due to the fact that the rennet actually in it is weaker than other brands and takes a bit of time to work.
I did this tonight with two batches. I had to re-add rennet to the first after it would not set up. I let the rennet sit out for longer than a half-hour the first time and made it useless. The second time I mixed it and poured it in and it came out great! Both batches are great and tasty and I plan to make riocotta tomorrow with the whey to make my own lasagna!
The best fresh mozzarella literally exudes milkiness when you cut into it, and I seem to remember the packaged store stuff calling itself "low moisture" so I'm thinking maybe the squeezing-out-the-whey step needs to be done in moderation.
Does the protein content of the milk make a difference? The milk I used was raw, grass-fed, jersey milk, so not exactly the same as your store-bought milk. Even at the slicing up the curds step, mine seemed to have more body than it looked like yours did, so I wonder whether to blame that on my milk or whether it could indicate needing more or less citric acid or whey. Any thoughts?
