It it a nice touch around your PC or anywhere in your room. It won't be able to light your room fully, though you may use such a bulb to see the keyboard keys in darkness or just add it to the interiour.
The process is relatively easy and there are no special components that you need.
Remove these ads by
Signing UpStep 1: Components & Tools
Components
- Bulb
- Green LED
- 330 Ohm resistor
- USB Cable
- Multimeter
- Soldering iron
- Soldering wire
- Desoldering Pump
- Hot glue
- Cable nippers and pliers
- * You may need a breadbord to do the prototype and test the if the resistor you use is right but you can skip this step
Visit Our Store »
Go Pro Today »
They will be a bit dimmer, but you will have more of them with NO wasted power in the resistor.
I think I might be able to help you skip a step: There's really no need to remove the glass from the base. Have a look at this instructable...
http://www.instructables.com/id/Concrete-Lightbulb-Wall-Hook/
...I've make a lot of these, with the concrete, and to use the LEDs you'dmhave to simply not pounch out the center glass stem inside the bulb. Remove the glass end on the base and clean it out, as you would in both of these instructibles, and carry on with the LED and Resistor.
I'll be giving it a try myself! :)
