The old laser module's enclosure was inadequate, and I wanted the new one to be sturdier, as well as having options to run the laser in continuous mode as well as push-button mode.
Remove these ads by
Signing UpStep 1Materials and Equipment
1 green laser module. (This particular module takes 5V to run.)
1 double pole, single throw switch.
1 momentary button.
1 4AA battery pack.
2 40mm PVC end caps.
1 short section of PVC.
1 40x40 piece of polypropylene plastic. (from a cutting board).
3mm metric fasteners. (Small bolts.)
Shrink wrap.
Solder.
Equipment used were:
Drill press. (I actually used a mini drill-press that takes a hand drill.)
Dremel with cutting disks and sanding wheel attachments.
Soldering iron.
Blow torch.
but it just looks so cool!
it's like an epic laser tool
Currently I'm having difficulty with the diode overheating - I suspect that while it gives out 50mW of light, it consumes a heck of a lot more electrical power, and puts out a lot more heat.
But its different with fluorescents , because the amount of heat they give out , + the amount of light = total energy .
That means 40W might actually mean 35W , because they don't have efficiencies matching LED's
for most states there are no laws but in vic they are completely illegal as lasers, but not as components of tools or machines.
you can buy 1mw red ones from cheapo stores, but you'd struggle to see the light that they emit :/
This particular power of laser pointer is borderline in Australia. I think the 100+mW lasers (e.g. Wicked Lasers) aren't allowed. The 10mW green laser pointers are legal, as long as you don't use them outdoors, especially near airports.
There IS talk about bringing in a law to require a license, which I think is overkill - they're not that powerful. :(
New to intructables?
its in the bottom right corner of a comment
