-Pollute the lakes and streams as the metals vaporize into the air when burned.
-Contribute to heavy metals that potentially may leach from solid waste landfills.
-Expose the environment and water to lead and acid.
-Contain strong corrosive acids.
-May cause burns or danger to eyes and skin.
Because of this I propose a clean green mouse
Remove these ads by
Signing UpStep 1Green Methods
METHOD 1
A solar powered mouse is not an obvious solution to this problem. You would think an office would not provide enough energy in terms of light. I was surprised to find a product out there that puts this energy to use and unfortunately I cant take credit for this Idea. Someone came up with it before me.
"Minister Cramer of the Ministry for Housing, Spatial Planning and the Environment is taking part in a user trial of the world's first exclusively photovoltaic-powered (PV) computer mouse."
source: http://www.tudelft.nl/live/pagina.jsp?id=e8c72be6-3452-4f04-b1ae-6d6b71f2b88d&lang=en
If I may say so, It is damn sexy
Unfortunately a solar panel is quite hard to integrate into a conventional mouse as there isn't much room with the batteries. A very efficient cell could be used so it doesn't have to be as large. It might also be uncomfortable to hold after the surface of the mouse has been altered.
It may be easiest to buy a relatively flat mouse and use a small solar panel, or even better, a flexible one and gluing it to the surface with resin. Many small solar panels could also be connected so that the panels lie flat.
Please comment below on any ideas you have
*Note: This instructable has no instructions and has been posted to inspire
![[mpn07] web Solar Powered Mouse ISOm.jpg](http://img.instructables.com/files/deriv/FS4/U6GH/F54HJ48F/FS4U6GHF54HJ48F.SQUARE.jpg)
Why not make a "shaker" mouse? Like the shaker flashlights. It is similiar to your second idea. I hope to see you build that one!
http://www.physics.lsa.umich.edu/demolab/exp/diodes.htm
I use a touchpad and a corded mouse, but I don't think there's anything wrong with regular rechargeable wireless mice. Nickel-metal hydride batteries are easy to recycle, and even when someone landfills them, they're not toxic like the old nickel-cadmium ones were.
Now, if you're opposed to nickel for some reason, or batteries in general, consider a capacitor. Build a voltage regulator that lets you put a capacitor in place of rechargeable batteries, and use a regular mouse with a charging cradle.
Or build a little dynamo in, with a crank or a pull-string. I think the string would work pretty well, since you could wind a spring which would pay out its energy into the dynamo at the right speed (similar to the Freeplay radios) without the bulk of a fold-out crank.
