3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Green Mouse
Green Mouse
Corded mice are a thing of the past. Computer mice use power, that we all know! How much power? Not enough for the average person to care. I'm sure that the millions of mice out there must add up to a substantial amount. Especially if you use rechargeable batteries. But that isn't my main concern. How many of you have a wireless mouse and have to constantly replace batteries to use it? And do you dispose of them properly? Heavy metals can enter the environment via a landfill and may produce the following potential problems or hazards:
-Pollute the lakes and streams as the metals vaporize into the air when burned.
-Contribute to heavy metals that potentially may leach from solid waste landfills.
-Expose the environment and water to lead and acid.
-Contain strong corrosive acids.
-May cause burns or danger to eyes and skin.
Because of this I propose a clean green mouse
Step 1Green Methods
Green Methods
All of the methods below would require a wireless optical mouse. I will discuss possible ways of modifing this conventional mouse to a more environmentally friendly device.
METHOD 1
A solar powered mouse is not an obvious solution to this problem. You would think an office would not provide enough energy in terms of light. I was surprised to find a product out there that puts this energy to use and unfortunately I cant take credit for this Idea. Someone came up with it before me.
"Minister Cramer of the Ministry for Housing, Spatial Planning and the Environment is taking part in a user trial of the world's first exclusively photovoltaic-powered (PV) computer mouse."
source: http://www.tudelft.nl/live/pagina.jsp?id=e8c72be6-3452-4f04-b1ae-6d6b71f2b88d&lang=en
If I may say so, It is damn sexy
Unfortunately a solar panel is quite hard to integrate into a conventional mouse as there isn't much room with the batteries. A very efficient cell could be used so it doesn't have to be as large. It might also be uncomfortable to hold after the surface of the mouse has been altered.
It may be easiest to buy a relatively flat mouse and use a small solar panel, or even better, a flexible one and gluing it to the surface with resin. Many small solar panels could also be connected so that the panels lie flat.
Please comment below on any ideas you have
*Note: This instructable has no instructions and has been posted to inspire
61 comments
1-40 of 61next »
Jul 25, 2011. 2:51 AMAegian2424 says:
why not have cord coming out of your mouse but instead od it being connected to you computer it be connected to a solar panel?
Jul 25, 2011. 2:49 AMAegian2424 says:
place a litle ball (like in the old .... mice) as you move the mouse around the ball would make the magnet spin and thus provide a current
Mar 15, 2011. 1:58 PM67spyder says:
Buy two sets of batteries from http://www.usbcell.com so you can keep one set charging in your computer while you are using the mouse that way when the batteries die you are only down for the few seconds it takes to change the batteries.
Sep 28, 2010. 5:34 AMDream Dragon says:
I just charge the beatteries with a little solar pannel in the window by my desk. one set in the charger, one set in the mouse. When the mouse starts to get unresponsive, just change them over.
Nov 16, 2007. 6:12 AMlabelreader says:
I switched to using a battery-free, uncorded Wacom mouse a while back. The tablet has a cord, of course, but the mouse does not. Most Wacom models come with both a pen and a mouse. Each device behaves differently in terms of the motion of the pointer; the pen positions the pointer in absolute proportion to its position on the pad (if the pen is in the upper left corner of the pad, the pointer is in the upper left corner of the screen), but the mouse moves the pointer relatively, just like a traditional mouse. The smallest model is not any more expensive than a nice Logitech mouse, and once you remove the snap-on clear part designed for artists, it's about the size of a traditional mouse pad.
Jan 3, 2010. 12:41 PMgaiatechnician says:
I use one too, as is.  It was a little anoying  at first because it does not act exactly like an ordinary mouse but after a while you forget.  I never took the clear part off. It works  automatically in linux and  I installed drivers for it in xp. (Mine must be 4 years old).
Jul 4, 2009. 9:31 AMscott! says:
Yeah, I use the WACOM Banboo Fun tablet myself, but it's a tad small to use the mouse, so I don't end up using it all the time.
Jul 19, 2009. 6:08 PM79spitfire says:
You could use a larger solar panel and "dock" for the mouse to recharge a Li-ion battery in the mouse. In any event the mouse or the panel has to be left in a sunny spot for recharging, making the mouse hard to use in daylight hours.
Jul 19, 2009. 6:03 PM79spitfire says:
You could mount a magnet in a tube inside of the mouse with a coil of wire wrapped around the tube. Then as the mouse moved side to side it would generate a small voltage and recharge a battery or cap. Look at how a "shakey" flashlight works. Just a thought...
Jul 4, 2009. 3:35 AMmzungu says:
I don't think there is enough movement to generate enough power to run the LED, the camera, the processor. You can easily calculate how much power going into moving a mouse with basic physics for Kinetic Energy, an.d you will probably sees that you will need to move the mouse non-stop.
Aug 11, 2007. 11:45 AMSpectrace says:
thats pretty cool. now that i think of it, the wireless mouse i use for my laptop batteries keep dying recently, but i just put in "dead" batteries i have already used to get the last bit of power they have. a comment i have on Method 3, thats basically the same idea used in graphics tablets too, for example the Wacom Graphire tablets (which is what every computer at my school uses). Great instructable
Apr 14, 2009. 4:47 PMdalbyman says:
Duuuuuuuuuuuuuuuuuuude. search for 'joule thief' on here, then search for 'micro joule thief' or similar, you could easily build one into a wireless mouse and possibly extend battery life by up to 100% (based on my expericance with an led torch)
Jun 18, 2009. 9:50 PMblakdragon19 says:
an led is somewhat simpler than a mouse. I understand your enthusiasm for the joule thief circuit, because i share it. unfortunately, it would be impossible to power amouse with this circuit. the joule theif powers LED's with undercharged batteries using an inductor and a transistor to collect power. the transistor allows power to flow to the coil and ferrite, which incucts current in both coils for a split second, but it is enough time for the charge to build up. once the charge becomes high enough to power the LED, it passes through the LED, to the ground of the battery, lighting the LED. this happens hundreds of times every second,so it looks like an unbroken flow of electricity, but it is in fact turning on and off faster than your eye can see. this would not work for a mouse, because the transmitter circuit requires constant power. keep innovating, the uses for the joule thief in daily life are endless!
Apr 12, 2009. 2:38 PMJohnnyDD says:
Call me old fashioned but what about an wind up mouse? Could it work? Maybe you could have one of those kinetic motors in there... and it will charge up as you move the mouse? And for emergency you could wind it up... Now that would be cool! Anyone got any ideas if this would work or not?
Feb 15, 2009. 9:51 PMblakeredfield says:
All good ideas. Also useful for keyboards. Idea 2 is used in my Seiko Kinetic watch. Very nice. You need some numbers to see whats viable and what isnt. Static electricity is never that useful, as current is very low.
Feb 7, 2009. 12:48 AMharolzoidium says:
Great ideas! But no matter how the energy is produced, some sort of energy storage would be necessary in the product.
Feb 4, 2009. 7:36 AMmrnatural says:
hey, what about using a mouse-wheel-generator instead of a mouse-ball-generator? i think wheels have much more movement than the mouse itself.
Sep 15, 2008. 10:55 PMhalonoob1234 says:
I use a microsoft laser mouse with a range of 10m, so I don't think any of these will be powerful enough to power it, except maybe the magnet pad one, but that one basically defeats the purpose of "wireless laser mouse".
Aug 14, 2008. 3:38 PMwhiteironhorse1 says:
have you thought about those flashlights that you shake? maybe you can use that in some way to make power.
May 28, 2008. 10:02 PMlittlechef37 says:
Several good ideas..... Wind powered mouse ? NO. Solar.... ? My hand is on it half of the day. Heat powered ? Your hand is getting warm on that mouse isnt it ?..... Hydrogen Powered.....Ok overdone Magnetically powered... ? I like this idea.... I use a tv a my monitor s o I don't have to worry about my screen turning green or purple. Generator... ? why not just a little electric generator inside your mouse ?? Static Electricity....? Your mouse pad is usually made of a fabric.....
Aug 4, 2008. 4:20 PMdombeef says:
nice ideas
Jun 1, 2008. 8:51 PMhumoogous says:
A4Tech already sells a wireless mouse that doesn't use batteries. It uses a special mouse pad that draws power from the usb port that in turns magnetically powers up the mouse
May 26, 2008. 7:27 AMCerne says:
These are very interesting ideas, but they aren't actually going to save any power. Solar panels still require a huge amount of electricity to make, a standard household roof panel takes 17 years to produce the amount of electricity it took to make. Also solar panels convert the majority of there captured energy into heat which would become very uncomfortable. As for magnets you know they only produce at most the amount of energy required to make them right? The kinetic charger might work especially if it's used in a similar manner to hybrid cars as a way of saving "wasted" energy. LED's are very energy efficient even the very bright ones in your mouse. Overall your best bet is too used a wired mouse, I have one that's lasted for almost a decade, or just recycle your batteries.
May 23, 2008. 7:09 AMtechnodude92 says:
Method 2 looks very similar to an automatic watch look it up on wikipedia. you could have two disks one positioned like this | and the other -- when looking at the mouse from the top. So that forward and back movementwill charge the batteries. or you could build a "shaker" mouse.
May 13, 2008. 7:43 PMAngus06 says:
Here's something I've been messing around with: I've got a solar panel I use to charge several rechargeable "AA" batteries with. I then pull out two of them (when they're done, which is especially important if they're Nicads) and toss them into the mouse and keyboard. In fact, this text being typed from a battery powered by two 100% solar powered batteries. Pros: Free, clean, renewable energy Cons: Somewhat frequent recharge (timing depends on current output of the solar cell array), and the mouse does not like the batteries very much. Rechargeables are 1.2-1.25 volts DC, whereas alkalines and the like (non-rechargeables) are 1.5V DC, so that is problematic with things like clocks, where the screen is much more faint. I've got rechargeable AAAs powering my uber calculator without a problem, so its that simple. I'll probably make an instructable soon on my various solar endeavors. In short: Solar-charge two AA rechargeable batteries (panel, blocking diode, battery holder, batteries), and put them in stuff. Brilliant!
May 13, 2008. 7:44 PMAngus06 says:
edit: a keyboard powered by two 100% solar powered batteries
Mar 6, 2008. 7:49 PMcoonass says:
My bet would be solar. Calculators manage to run on relatively tiny solar cells... if your circuit involved an efficient enough battery and solar cell combination, there's plenty of real estate inside the average mouse to mount the added power circuitry. I personally own a few mice which have flat surfaces and can take a solar array larger than anything I've seen in a solar calculator. Alternatively, you could have a metal-bodied mouse with thermocouples which might be able to charge internal batteries. I mean, the load's an LED and a phototransistor or photoelectric cell. The waveform from the mouse is shaped by the shutter mechanism between the LED and photodetector device - no signal processing beyond that required. It's not as though the electrical load from the mouse represents a major drain on the computer - the idea is simply to get the heavy metals from mouse batteries out of the trash stream. If this is such a worry, it seems to me that the best move is to either go back to hard-wired mice or have a USB-powered mouse pad which is also a low-level RF emitter, which would induce a current in a wire induction loop and rectifier assembly inside the mouse. Even simpler - have a thin-film microdiode or transistor grid array built into a wired mouse pad and a mouse whose only active component is a pin-sized magnet which would cause voltage spikes at points inside the pad where the magnet passes. The mouse itself has no electrically powered or even moving parts inside - but there's that pad, which would draw a tiny current from the USB port into which it was plugged. Design Copyright 2008, Vance P. Frickey
Feb 4, 2008. 6:07 PMJazzmanSA80 says:
I'm not a fan of this type of mouse power because it's not really a "green" mouse like the other methods. If you are going to use a mouse like this, you might as well buy a wireless mouse with internal batteries and a charging dock. You can use that anywhere, not just on the supplied surface, and a 2 hour charge can last you about a week with many of the mice out there. I encourage you to focus on the motion-powered method, because it is the only feasible method that is totally power-independent.
Feb 4, 2008. 6:00 PMJazzmanSA80 says:
My bet would be on motion. If you were really tricky you might even be able to get a Sterling engine to generate enough power from the heat of your hand? I'm not sure if one that would fit in a mouse could generate enough power though. It probably can't. Plus it would probably vibrate the whole mouse. Ahem... so yeah, motion sounds good lol.
Dec 17, 2007. 1:12 PMAmall23 says:
Reading these comments I just had to create an account and post my own comment.
Why not make a "shaker" mouse? Like the shaker flashlights. It is similiar to your second idea. I hope to see you build that one!
http://www.physics.lsa.umich.edu/demolab/exp/diodes.htm
Dec 3, 2007. 4:35 AMmunchman says:
Use a laptop. Then you can use the trackpad instead!
Dec 2, 2007. 1:38 AMaureliansh says:
you simply must join my group alternitive energy your idea is revolutionary you should sell your idea
Nov 4, 2007. 2:10 PMEmmanuel101 says:
I've been thinking about a 'green' mouse as well, and your idea in step 2 looks like a good one to me. I'm not sure about method 2 here though, how would it create power? As far as I can tell, the magnet and coil will not move relatively to each other, so no magnetic flux would be induced. Please point me to what I'm overlooking here.
Oct 26, 2007. 10:37 PMSarten X says:
Regarding method 2, and the concern of not enough power being generated from the rolling magnet ball. Power is related to the strength of the magnet, the orientation of the magnet and coil, and the amount of coiling. First, use a powerful magnet. You mentioned strong magnets near computers not being a good idea... Actually, it's not magnets that are the problem. It's magnetic fields. Those fields can be contained inside a shield. I'm thinking the mouse itself could be shielded, and connected to a mousepad with a wire. That wire would do two things. First, it'd connect the shield of the mouse to a metal plate, which should make the shield almost complete (there would be a small area not protected, but it should be enough to make Mr. Faraday happy). Second, the connecting wire would be parallel to another wire, that would act as an antenna for transmitting the mouse's signal outside the shield. The other two points are simple. If the magnet spins around its poles (like the earth does, or at least tries to), no power would be generated. This can be fixed by forcing magnets into close proximity to each other, in perpendicular orientation. When one magnet is spinning around its axis, the other is flipping, generating maximal power. I envision a 3-layer magnet sandwich. The axis of the outer magnets would point like a toothpick through the sandwich. The inside magnet would be perpendicular to that, pointing out of the sandwich. Lastly, the amount of power generated is also related to the number of turns in the coil. More turns, more power. It shouldn't be hard to see where I'm going with this...
Aug 14, 2007. 12:45 AMVIRON says:
I think a motion-charged wireless mouse is possible and a great advance in mouse tech. There are many great ideas here that may work.
Aug 12, 2007. 1:58 PMMyself says:
The inductive pads waste a *lot* of power in order to transfer enough into the mouse for it to be useful. Optical mice have a pretty bright LEDs, which take significantly more power than the encoder-wheel style of yesteryear.
I use a touchpad and a corded mouse, but I don't think there's anything wrong with regular rechargeable wireless mice. Nickel-metal hydride batteries are easy to recycle, and even when someone landfills them, they're not toxic like the old nickel-cadmium ones were.
Now, if you're opposed to nickel for some reason, or batteries in general, consider a capacitor. Build a voltage regulator that lets you put a capacitor in place of rechargeable batteries, and use a regular mouse with a charging cradle.
Or build a little dynamo in, with a crank or a pull-string. I think the string would work pretty well, since you could wind a spring which would pay out its energy into the dynamo at the right speed (similar to the Freeplay radios) without the bulk of a fold-out crank.
Aug 12, 2007. 4:54 AMlemonie says:
So this isn't finished? How about unplugging the mouse and using the keyboard? (or has sofware become so mouse-orientated that it's not practical anymore...) L
1-40 of 61next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:puffin_juice
