Step 7Back to the roof
Back to the saw; using the panel measurements, cut some 2x2 inch battens to hold the panel in place, the batten for the top must be beveled to match the roof pitch.
Using these battens fix the panel to the roof frame, I attached the battens to the plywood with screws and construction adhesive, but used only screws to attach it to the roof structure to allow eventual replacement if needed. If you wish additional waterproofing of the plywood can be done now, I brushed on a coat of water seal because this plywood had already spent the three years since the hurricanes sitting behind my shed.
For drainage we'll drill a couple of 2 inch holes along the bottom edge of the panel and fix nylon screening over. Along the top ridge, for the comfort of the dogs, caulk was used to seal the cracks to prevent dripping.
Add Comment
