Green Solar Powered Water Barrel
A Green way of using rainwater with the convenience of city water. The attached solar regenerated pump enables you to water plants with pressure, even when the water in the barrels falls low enough that it barely passes the level of the faucet. The sun-warmed water also aids in the growing of plants as it does not shock them. The twin 85 gallon barrels are raised onto a very sturdy 4x4 box assembly from recycled wood, held together with new carriage bolts because the total weight of all the water when full is approx 1700lbs. This frame is resting on eight 2 inch thick 18 inch square cement pads to prevent sinking. The barrels are raised to increase the head pressure and decrease the work load on the pump.
Vote for me if you think my idea is worth passing on to show people being green doesn't have to mean sacrificing quality or convenience . Thank you for taking the time to look at my instructable!
Step 1Water supplied from mother nature
water supplied from mother nature
link barrel to downspout. ensure top of barrel remains below level of water entry. I found the Watersaver attachment for the 3x4 downspout pipe works perfectly. In order to enable adequate water flow to the barrel I adapted the Watersaver attachment by drilling out the side and adding a flange for a 1inch PVC fitting. I sealed this by using a rubber gasket and additionally using a silicone sealer. Ensure there is a downward slope between the downspout and the barrel entry.
138 comments
1-40 of 138next »
Oct 9, 2011. 12:53 PMgfwhell says:
In order to keep water free of bacteria, (Stagnating). bubble air through it, better still, ionize the air first, This is called Ozonated air. check out ALIBABA for cheap ozonators or make your own with an ignition coil and a bundle of Fluorescent tubes used as electrodes. you will need a pump to mix the ozone with the water,so a solar cell, battery and inverter will probably be required, do what I did Scour the USPatent office for information on water sterilization and apply your brain to someones invention, your welcome to copy whats there provided you dont try selling it. Of course you could make a filter and force the collected water through it, if you make it properly the water will soon contain no bacteria after passing through the filter, a couple of layers of ordinary surgical lint should surfice. you could sterilize the first gallon or two with a spoonfull of hydrogen peroxide. the filter gets more efficient at trapping bacteria the more water that is passed through it. GF
Sep 9, 2011. 11:11 AMvov35 says:
Here's a thought on saving some power:
1) make a T on the pump's output, and attach a small diameter vertical tube around a foot tall; allowing the remainder of the water to flow through the straight portion of the T and function like normal
2) To the vertical tube, attach an endcap with a hole in it to equalize air pressure.
3) Drive two screws into the vertical pipe at a reasonable height. Connect these to an inverting circuit, like used in: http://www.instructables.com/id/Laser-Trip-Mine/
You should use much larger resistances and a power mosfet.
4) the mosfet throws a relay to turn on a pump. This will only happen when the water level is below the screws you set.
The goal here is that the pump turns off if you're not releasing pressure from the hose; allowing you to use a watering handle for the end of your line. Depending on your pump you may also need to install a check valve, to allow the hose to stay pressurised with the pump off. The height of the screws installed in the vertical tube will be directly proportional to the water pressure that will be maintained in the line.
... If I actually made the system and had photots, I think it would be instructable worthy, however, I don't have a rain water system to experiment, and will instead suggest that you try it out with yours.
Sep 9, 2011. 12:56 PMvov35 says:
I hadn't read to the point when you mentioned that your pump had an automatic shutoff, but it's still worth considering in my humble opinion. :p
May 30, 2011. 10:45 PMhhart says:
Absolutely awesome. I'm definitely doing this and thank you for putting this up!
May 7, 2009. 9:59 PMThe Lightning Stalker says:
If you look around, you can find an all plastic pump that won't rust out from the rainwater. It's important that it's a jet pump so you get enough pressure to run the attachments. Or you can get a submersible and put it in the bottom of one of the barrels. That will give you huge pressures though so you'll need a regulator. Either way, never start the pump with the attachment(s) turned off or you will get cavitation which wears out the impeller(s). If you hear a louder "swooshing" sound, turn if off right away. That means it's cavitating and you don't have enough flow on the output for that size pump.
May 8, 2009. 10:30 PMThe Lightning Stalker says:
I'm not attacking your pump or your instructable or anything. I'm just trying to help out people who don't know anything about the pipe and the pump and the ppppp... If all someone can afford is a used jet pump, then it works good enough.
Aug 12, 2010. 9:05 AMjerhpk says:
I'm looking for a part-time pump for a smaller application. What is the flow rate on the pump you have? I'm not planning on running the pump for more than 30 minutes at a time, and maybe once a week. (The planned height of this project is about 8 feet, maximum. It does not need to be high pressure at this location, but it does need to spray slightly. Yes, I realize this is contradictory.) I do appreciate this instructable; I find I reference it frequently for a variety of projects. as a question, do you have the "sight level indicator" going into a hole in the top of the barrel, or just tucked under the lid? And is the top of the tube higher than the "overflow" holes?
May 27, 2010. 2:41 PMT3h_Muffinator says:
This is really neat!  The pump was a great idea!
Do you think the water's drinkable?  If not, maybe adding a purifier might help with that.  (I understand that this is just for watering plants, etc., but the prospect of a rainwater purifier is tempting)
Awesome work!
-muffin
Dec 14, 2010. 12:12 AMswilus says:
If you add a sediment filter and uv this water would be perfectly fine to drink. Rain water is naturally soft. If you are really nervous about drinking, add an under sink reverse osmosis system: http://jandjpumps.com or any hardware store!
Sep 17, 2010. 7:05 AMtoogers says:
i'd use quite a few filters on this, it was, after all, sitting in a storm drain.
Apr 6, 2011. 3:28 PMkyuubiunl says:
BETTER filter, not more.
Sep 2, 2010. 9:06 AMDavidM45 says:
great project! I have found that valves on a plastic line are so much better with a support like a 2x4.
Aug 16, 2010. 12:47 PMjerhpk says:
FYI: Lee Valley has a downspout adapter for sale for under $20. It has two garden hose fittings on it, to hook two rain barrels up simultaneously. Biggest reason I'm considering it (the adapter) is that it is something that does not need to be removed to shut off water flow to the rain barrels. (Local codes state that rain barrels are ok on homes as long as they are emptied and disconnected during the winter months. "Winter months" is an unspecified length of time in the code as of last time I checked, but I assume it to be when the temperature is low enough to warrant frost warnings, or similar. Codes have no such restrictions on "Non residential or non commercial" buildings, such as workshops or garages.) .
May 16, 2010. 2:49 PMBoyd Carl says:
Good idea! What is Make & model of water filter? What is good source(s)?
May 16, 2010. 2:52 PMBoyd Carl says:
Does the water saver attachment have a strainer to keep leaves, etc.
from getting into barrel?
Jun 11, 2010. 9:41 AMpickford78 says:
You can find cheap 50 cent filters that go into the gutter to filter leaves out.
May 12, 2009. 9:40 AMLancePenney says:
Do you have a charge controller between the solar panel and battery? Or maybe the panel has a charge controller built in? Excellent project by the way.
May 28, 2010. 7:44 AMEntropy512 says:
Are you sure, or is it just the "panel not large enough to damage battery with overcharging" approach?
Most people have used 5 watt panels with car batteries without any charge controller.  (I do for maintaining my rarely driven convertible's battery.)
Apr 11, 2010. 11:05 AMpbhound says:
you could put a small colored float in the tube to make it easier to read from a distance.
May 16, 2010. 9:39 AMTangerineB says:
Ok, jumping in here late in the game - and I'm just beginning to learn how to garden (and build things!).  Wondering if there is any use for my old garden hose that split at the end when we didn't get all the water out over winter. I'm looking at longterm plans for rainwater collection and underground watering - it's just going to take a while during our remodel. Should I keep the hose or toss it?
May 27, 2010. 2:46 PMbunglesmate says:
 I hope I'm not stating the obvious but can't you just reterminate the end of the hose. It'll be a little shorter obviously but should be good. Or use a set of adapters to create a short extension for the long length left after the split.
May 27, 2010. 1:09 PMSinAmos says:
I've been wanting to do something like this for a while.  I have my tank, but I have yet to get the run-off adapters.   Thanks for the inspiration.
May 27, 2010. 7:10 AMdepotdevoid says:
Awesome project!  I've added this to my ever growing list of things to do around the house!
May 7, 2009. 10:06 AMrayzentz says:
I like this. However, where I live, it is illegal to collect rainwater. How stupid is that?
May 11, 2009. 1:05 AMWilderLust says:
most places that say it is illegal mean open containers... if you have a closed tank then they are ok. i live in one such place... it is illegal to have a rainwater collection but if you have a closed system it is ok. it is cold in winter here so i have a couple of 1000Gal tanks under ground which allow me to water all my fruit trees, flowers, greenhouse plants with only rain water with exception of rare extra long rainless summer months. i have old hoses underground watering the trees at the roots to minimize evaporation too... it is very efficient.
Apr 10, 2010. 5:05 PMecarrilloalbarran says:
Hi WilderLust, could you post some pictures of the system you described?
Thanks
Apr 12, 2010. 1:15 AMWilderLust says:
hehe... well... it is all underground so pics are of no use; i did not take pics when i was making it years ago anyway. it is not really that hard, just dig a big hole, bury a big tank (or more depending on volume needed, and $), rum pipes from your gutters, place a pump in the tank to pump out the water when in need, and you have it. of course i have a pre-filter (55gal barrel) to get the junk cleared from the water before it gets to the big tank. you do not want to fill your tank with dirt, leaves, and other stuff washing off your roof into your tank. i also use a DC pump which i power with solar recharged batteries but that is an optional thing. some day i will make a wind powered pump too since we get decent wind around here. for big tanks, look at your building supply warehouses... they are not cheap when big but they are a permanent investment for you that will collect water for decades. i use PVC pipes in my system
May 18, 2010. 11:05 AMSn-Dlouwho says:
Some of you out there might be able to find someone in your area that sells used containers cheap.  The pop companies in your area is a good place to start,  I think you could pick up the barrels  for 6.00 - 10.00 each.   You'll have to rinse them out!  Check online...
Mr. WilderLust,  Your idea sounds great!!!  What state are you in?   Is your pump used to pump out the h2o when needed, is that for the 55 gal. drum when it gets full to release for over flow?   For the filter,  what kind of filter?  Where is it, at the top circle opening where the rain water comes in?  Could you draw pictures of how you did it,  laid it out in your yard.  Can you take pictures of  what is above ground.  I don't understand how you have hoses or pvc connecting all over your yard to the tree roots, and gardens etc.  Did you drill holes in the big tank, and connect pvc pipes tunneled underground to the locations?  My husband is always squawking at me, about leaving the garden hose on after water my plants and flowers.  This sounds like the perfect solution...  I'll be a good woman, and be able to save him money!!! haha!  Thanks so much!
May 18, 2010. 12:47 PMWilderLust says:
i get my 55gal barrels for free from a laundry department that gets their laundry detergent, bleach, etc in such barrels then recycle them.
The gutter downspouts are routed (under ground) to the tanks. the 55gal barrel is the filtration tank with layered media to trap larger impurities. i use bug screen on top and polyester batting below it and clean it out a couple times a year. this keeps rocks, leaves, etc out of your storage tanks. this barrel sits on the manhole access port to the storage tank and the filtered water just drip into the storage tank. in fact the collection of water is all gravity fed. the pump is in the storage tank(s) and is used to pump the water up to the plants (through pvc pipes).
i am developing a smart watering system which is microprocessor controlled and allows me to control how much water each zone gets but this involved electronicaly controlled valves and severely increases cost. i need it because i have an acre which will be nearly all under cultivation of food bearing plants so i need much more control than if you are watering typical gardens. most of you can get away with a simple timer on the pump to dictate how long it will run and water your garden. for most gardens, i would recommend a drip watering system... you can buy them at most home & garden stores. my system is a glorified drip system... in fact for most of the plants it is a drip system but for my fruit trees, i have made a pvc pipe into a circle, drilled tiny holes in it on the bottom, and buried it under ground where it delivers the water to the drip line of the tree. this eliminates evaporation and helps weed control and gets the water directly to the place most needed thus requiring far less water to be used.
As mentioned before, there are no signs of any of this from above ground because it is all underneath. the only thing you see is a manhole cover which gives access to the filters and the tanks for cleaning if needed.
The web is full of info... many commercial sites that can give you great ideas for doing it yourself. Some sites to visit for ideas:
http://www.darcoinc.com/
http://www.plastic-mart.com/
http://www.ntotank.com/begrwata.html
May 18, 2010. 3:28 PMSn-Dlouwho says:
Thank You for the information....  The next time you put this together (maybe for your kids, neighbor or help someone from church), you could take step by step pictures and/or videos.  hint, hint!!!  That would really help alot of people....    When you develope your microprocessor controlled system don't forget to take pictures and/or videos...  Thanks again!
Apr 12, 2010. 1:43 PMecarrilloalbarran says:
Thanks for the info, i'm an engineer living in Mexico and I want to implement some simple sysytems in new homes, so thanks
Apr 12, 2010. 3:50 PMWilderLust says:
here is the kind of tank i use http://www.ntotank.com/begrwata.html
the best deal is the 1450 Gal @ $979 and 1700 Gal @$1149 both of which are .68/Gal
Jul 31, 2010. 7:54 PMandy1917 says:
MAY I ASK , HOW DO YOU KEEP THE WATER FROM BECOMING STAGNET? i HAVE BEEN TRYING TO DESIGN A SYSTEM FOR MY FAR HERE THAT I COULD STORE WATER FROM THE WINTER FOR UP TO THREE MONTHS DURING DRY TIMES. MY CONCERN IS THE WATER WOUDL STAGNET AND BECOME SEPTIC. dO YOU HAVE NAY ADVICE?
1-40 of 138next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:damoelld
