Step 9Water Gauge
This was fun to install as I didn't want to waste all the nice rainwater and drain the tank before I drilled a 3/4" hole in the bottom of the tank to install the angled shut-off valve. Reminded myself to only use a battery powered drill :)
I reused some 1/2 inch plastic tubing that I had left over from another application and connected it to a 3/4 inch angle valve with a shut off (which came in handy during install)
I sealed around and under all penetrations into the barrel (valve and screws) with a two part epoxy that was a water proof filler and sealer.
It is important to not completely seal the tube or the level will not change to reflect the level in the barrel.
comments
Add Comment
damoelld (author)
says:
Add Comment
