Green Powerless Telephone
Published
Introduction: Green Powerless Telephone
Hi all !
This is my first project on instructables .
I would like to show you how to make a working electrical telephone that does not need any power to function .
I hope that you can read and understand the schematic diagram . I am sorry , but it was already built so i could not make step by step .
This device is simple to build , so anyone can make one . Sure , this device does not ring like conventional telephone , but with some modification , you could add some ring and a dynamo to power the ring while calling , but that is up to you . Earpieces used in this project are high impedance . I did not measure them , but i think that they are around 600 Ohm from used telephone .
Note that when speaking the sound is not very loud , so i think that loud people will not have problems using it :)
I suggest using it in a quiet environment .
Well , i dont see any practical use for this device so you will have to figure out where and how to use it .
But kids like it .
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    14 Comments
    you should do the same with two radios and two transmitters! wireless!
    Thanks, the best Instructable so far, if you could have boost the sound with a transistor and a battery that also would be great
    Hook a small hand crank generator to each handset and run them through a switch board you could be your own phone company! BUT WAIT! THERES MORE!
    FREE LONG DISTANCE CALLS dam if only i had a 100KM cable
    Nice build. instructions are a must- i would like to point out tho, that all corded telephones dont need power, u make it sound like its something knew u came up with.
    what i mean is you can connect two normal telephones to get the same effect - i remeber my cousen doing it, using a little adapter.
    Respectfully; that's highly unlikely, unless the "adapter" contained a battery. Phones ment to be used with the standard telco system modulate a DC current. Voice powered phones create the current. The standard phone microphone element can't produce a current. Voice powered phone use a dynamic microphone that can produce a small current.
    "This device is simple to build , so anyone can make one" Instruction on how to actually build this would help those that dont know how to.
    I'm in the US Navy, and we use these all the time. If the ship loses power we still have damage control communications. They are called, simply enough 'sound powered phones'.
    Well i have never seen anythig like it before . Actually i discovered it by coincidence . There is no instruction needed to use this device . You just have to speak loud and clear so the earpiece you are talking to can produce enough electricity to send it over the cord to the other earpiece where it converts back to sound . That is all . I wanted to add two motors connected to the dial , one for each telephone to power the small beeper so it can actually ring (one would have to turn the dial connected to the motor which would produce electricity to power the beeper) , but i didnt have any old telephone just the handles from differet phones. I know that the telephone can be powered with adaptor or even a battery but the telephone i made doesnt need power :) Weekend is close :)
    i think this is a great idea....i'd love to have something like this with a cable run between my upstairs and downstairs.
    neat idea but I guess I prefer the old school string and tin cans, mostly because the old phones from ma' bell are kinda had to come by at times
    I will be working on that over the weekend hopefully :) Well I realize that this is the point of Instructables so i will try to do my best .
