3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bungee Launcher
Step 3Rubber tubing
Rubber tubing
50 - 100 feet of rubber tubing. UV resistant if possible. Normal surgical tubing isn't UV resistant, and it will get brittle after too much time in the sun. Tie a key ring to each end and tape or heat shrink them too as shown in the photo.
For my set up it was 50 feet of UV resistant latex tubing purchased on ebay for $20
3/8 inch outside diameter 1/16 wall.
This is for BIG PLANES over a pound, and is a very fast take-off on my glider.
For smaller, lighter models weighing in at under a pound, 20-100 feet of 1/4 outside diameter tubing is good. And you may not need much if any tow line for tiny park flyers.
You'll notice I'm not giving exact numbers because as long as you have very stetchy tubing with enough pull, your highstart will work!. The longer the tubing, the more gentle and higher your launch will be.
What is important is that you'll be pulling 5 to 10 times the weight of your plane on the tubing to provide take off. If you have less pull than the weight of your plane, no take-off.
For me 8 - 10 pounds will get a good launch because my plane weighs two pounds.
To get higher launches you can use more pounds of pull or add more tubing.
The higher the pull/weight ratio is, the quicker and more dangerous your launch will be.
4 comments
Feb 23, 2010. 11:24 AMmatt1606 says:
 agreed with both of you two. someone really needs to make a banshee bungee and show everyone how to. ive been trying to find bungee but i cant get any anywhere
Apr 15, 2009. 9:04 PMSwarm200 says:
you used this material before do thing i could use multiple cords to make a banshee bungee launch system for, skating...youtube or google it?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
207
Author:Frivolous Engineering(FrivolousEngineering.com)
In December 2009 I published The Most Useless Machine Ever. 2011 formed The Frivolous Engineering Company Inc. in order to supply Useless Machines to the masses.
