Greenhouse From Old Windows
Step 11Edit: Fan Window
Edit: Fan Window
I was unhappy with having to remove the fan/vent window and having to prop it against something while cooling the greenhouse during the day. The frame was already designed to fit the window into it. I decided to have it slide up and be held in place. I started by salvaging some hinges from an old entertainment center. They are the kind that sit completely outside the door. Plus these had a unique shape that fit around a right angle. This allowed the wooden "stops" to swing in place and hold the window up while I was venting or when the fan is in place. Across the frame I nailed some boards to hold the fan window against the frame. Lastly, I found an old pulley and fastened it to the window so I can pull it up easily.
1 comment
May 18, 2010. 6:12 AMceknight says:
You've got some very ingenious little bits in this greenhouse. Love the hinged window stops for the vent area. Great job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
44
Author:cheft
