Pull Tab Fire Starter
4,384
94
6
Published
Introduction: Pull Tab Fire Starter
About: Make stuff!!!
Hello in this instructible I will show you how to make the grenade fire starter
things you will need:
toilet paper roll
painters tape
matches
scrap cardboard
lighter fluid
container for the lighter fluid
and the match striker from the side of a strike on box match
Please be careful, this instructible deals with fire
Step 1: The Matches
gather two matches and place them side by side, then get the striker and tape one end with the painters tape to act as a handle ,then place the matches on top of the match striker( you can find one of these on the side of a small match box)
Step 2: Tape the Matches
once you have the two matches placed on top of the striker tape it with the matches facing up so you can pull the striker out smoothly, then tape the matches tightly to the side of the toilet paper roll about two inches from the top, once it is all secure roll the scrap cardboard and place it inside the toilet paper roll
Step 3: Light It Up
once it is all secure and you are ready to start the fire, get the container and fill it about a quarter of the way with lighter fluid, then dip the top of the fire starter in the fluid and be careful not to get the matches wet, then once the roll is saturated at the top pull the tab hard to the side and toss into the fire pit
I am not responsible for anything that may happen, this project uses dangerous elements, use at your own risk
this is for educational purposes only
Step 4: (preferred) Pine Sap Version
I realized that the lighter fluid was a little dangerous so I came up with a solution, pine sap is very good for fire starters because it contains turpentine, so all you need to have for this version of the pull tab fire starter is
pine sap
and the original pull tab fire starter
You start with the original fire starter, but instead of the lighter fluid you would use pine sap, cover the top of the fire starter with the sap(as shown in the picture) make sure the matches come in close contact with the sap, and you might need to add a match because the pine sap is a little harder to catch on fire, after you cover the top of the fire starter it is ready, and the good thing about the sap is that you can store it away for months and still be able to use it, unlike the lighter fluid that goes away after a few minutes
If you make this project please post a picture and show others how you made it, and feel free to expand on this idea I would love to see your ideas, and we can learn from each other and always be safe.
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    6 Comments
    I have updated a safer option using pine sap
    Do not dip the tape into the lighter fluid, you'll get a nasty burn.
    yes only dip the top, and I'm going to replace the lighter fluid once I can get some pine sap
    Could you please explain the pinesap? I'm confused, or are you not talking about the pinesap from the tree?
    When I am able to get some pine sap I'm going to put a ring of sap around the top of the toilet paper roll so that when the matches go off and it will catch the sap on fire instead of using the lighter fluid which is much more dangerous
    awesome, I can't belive I've never thought of this
