Grim Reaper Animatronic
A few years ago, I got into Halloween and decided I wanted to make an animatronic figure to decorate my house with. I wasn't really good with electronics, so I used what my skills were to make the animated figure. I decided that my animatronic figure would be the Grim Reaper...
What you need to do this project is:
-Wood- You need to build the animatronic's armature out of something. Wood seems to work just fine. I used scrap wood that I had around the house.
-Small Oscillating Fan- This is what I used to animate the prop. The Grim Reaper would turn his head from side to side.
-Skeleton Mask- I found one at Party City on clearance for $2.99. It worked...
-Black Sheet- Dress up your Grim Reaper. I actually used a black tablecloth.
-Sickle- The Grim Reaper carries around his sickle. I made one out of a palm tree branch. Get creative.
Step 1Build the armature
Build the armature
I built the armature of my Grim Reaper mostly out of scrap wood. When I ran out of wood, I used some PVC pipe. Building the whole thing out of wood or building the whole thing out of PVC really wouldn't make all that much of a difference.
How exactly you build it doesn't make all that much of a difference either. All of this will be covered up, so as long as the frame holds up, it will work. An important feature of my design is to put a flat piece of wood at the top of the frame, where the neck would appear to be. This is where the fan will go, so it should have a stable place to sit. Build your armature accordingly based on how your fan will fit into the frame.
13 comments
Oct 15, 2010. 5:44 AMhalloween_haunter says:
Saweeeeet! I am always up for the spooky but cheap way. Thanks !
Sep 25, 2010. 1:00 AMScreamo says:
Pretty cool
Nov 2, 2007. 3:00 PMKiteman says:
Do you have the fan spinning as well as the oscillation running?
Sep 13, 2010. 8:39 PMtenaciousbd says:
Once I removed the blades, I had a problem burning up fan motors. I remedied this by rigging up a motion sensor so it would only come on when needed.
Nov 8, 2007. 4:29 AMKiteman says:
Or pump fog under his shroud and it will pour out of his eyes and mouth...
Oct 21, 2009. 4:10 AMTheSweetRevenge says:
this is great xD
lol, i thought this would be harder XD
will definitely do this for halloween =D
I'll try fattening the arm up with newspaper >   <
Oct 15, 2009. 7:42 PMannoyingfeatures says:
 clever, i want to do this
Sep 29, 2009. 11:21 PMseastar128 says:
be careful with lasers as they can harm real eyes causing burns to the retina...depends on many factors including the "strength" of the laser, exposure, etc...LED s would probably be a better and safer method...but good idea
Sep 18, 2009. 10:14 AMhauntedscene says:
This is creepy and cool. Just what I need. Thanks for posting
May 25, 2008. 11:06 AMbounty1012 says:
you should add a bowl of candy and make it move when someone tried to get some candy that would scare the crap out of them
Jan 17, 2008. 3:43 PMelescape says:
Yeah, i would use laser pointers, i would just add some leds, and would be a cool idea to just add like a trip sensor so as soon a a kid walks by, bam, it's turning around and all.
Nov 2, 2007. 4:17 PMcanida says:
Simple and functional! I'd recommend adding cheap red laser pointers for extra-spooky eyes.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:woofboy111
