Grind Box
7,321
12
Posted
Introduction: Grind Box
How to make a simple strong grind box for bmx or skateboard
Step 1: Getting Parts
First thing we did was find 4 planks of wood 100 inch long x 8 inch wide x 3 inch thick
Step 2: Cutting
We then marked the middle of the plank all the way down and cut all the planks straight down the middle with a jigsaw. 1. Leave one plank just cut down the middle. 2. Cut the second down the middle and cut into 25inch lengths. 3. This should result in eight 25 inch planks.
Step 3: Making the Base
We then took the two long planks and put 2 of the 25 inch planks on each end and screwed them together. We then put another 25 inch plank in the middle for extra support.
Step 4: Making the Top
Next we got the other two long planks and did the same as the base but this time there is eight planks in between. We measured of equal distances of 14.3 inches and screwed the planks in place.
Step 5: The Supports
We cut up the remaining planks in to 22cm blocks. We then screwed these to the top by drilling the screws in diagonally.
Step 6: Assembling the Frame
We then put the base on top of the screwed on supports and then screwed the other side of the supports to the bottom side. Finish it up and turn it back over.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    3 Comments
    Why did you buy 3x8 inch why did you just not buy 2x4x8 ? That would take a lot if time off for you
    @bmxlove ye we are going to put coping on we just have to get some first
    Can you put metal on the sides ?
